zj lift ?
well i just got my new 265/75/16s yesterday and ordered my 3.5" rough country lift.. Was curious if there is any tips or anything i need to be made aware of before installing the lift any help is appreciated thanks :smiley_drive:
K2ZJ
If you undo the sway bars and shocks, you can install the springs without a compressor. It helps to have a friend stand/push down on the axle when you are putting them in. If you kit comes with arms you will want a good ratchet starp to keep/put the axle in place to put the arms on. Not to tough of a job. Good luck.
K2
K2
thanks for the heads up have you had any problems with the cv joints on your zj ?
BigDaveZJ
Start soaking stuff in PB Blaster or your other favorite penatrating oil and it will make things much easier.
oskarf150
