Bring on the Tech
David Harris
When I swapped the axles I built a custom suspension that has gone thru way too many revision to count...Basically it sit's the same height as D2 with a 3" lift...
I limited up travel to 6" and down travel is the full length of the coilover, which is gives it about 22" inches of wheel travel...
So these are the entire Toyota axle assemblies, not just the thirds and shafts . . .? Must have a lot of hours of work in there (understatement).
Clemtiger84
