My Camping Trailer Project
Dirtco
Once I got the spindles welded up I got to work on the spring perches. I cut some square tubing in half, then notched it for the axle tube and welded it together.
Then I greased the bearings, installed the hubs and painted the axle.
Dirtco
The stock tires in the first pictures were so dry rotted they would not hold any air. So I searched through our junk tire pile and found some wore out 15" tires that would hold air, some big old 205's :D. These will be used to roll the trailer around until i get the real tires and wheels later down the road.
I also got the gas tank skid plate sanded and painted.
I picked up the springs too, they are the 4" Superlift springs that used to be on the truck. I gave them to a friend years ago and he never used them.
First I had to get it in the shop, I think I should leave it like this!
Dirtco
First I picked up the springs that used to be on the truck. I gave them to a friend years ago and he never used them. They are 4" Superlift springs, and were stiff as hell back in the day, so I needed to pull a leaf or two to soften them up for the light trailer. The springs only have three leaves, plus the overload. I removed the overload and the middle spring from the pack.
Dirtco
Before I installed the leaf springs I added a little bracing to the stock spring hangers.
I got some 5" TG Shackles and installed the leaf springs.
The U-bolt plates that came with the U-bolts were too narrow for the larger truck leaf springs, so I had to make some new ones (I'm waiting to trim the U-bolts until I know the spring pack will work right).
Dirtco
I officially have a trailer, it rolls and can be towed!
With the suspension figured out (for the most part, I still need to mount the shocks), I started planning out the tongue length and configuration.
Dirtco
I knew the tongue needed to be cut down, so I wheeled the trailer outside and started taking some measurements. I had to be able to jackknife the trailer without it damaging the truck or itself, but I also didn't want it too long.
I wanted to be able to switch between a normal coupler and an off-road coupler, (I also wanted some extra theft protection) so I added a reciever to the tongue.
Dirtco
I also added the final bracing to the tongue. There will be more bracing behind the tongue when I build the storage box.
