"Annoyed" would be a correct word to describe our mood. We could still see were we tipped over last time and we knew how much digging it takes to get the car righted again.
No choice... out came the shovel... and eventually we got out again... and it did not take another kilometer before we... tipped over again... and again..
And again.
At this rate it would take years to get us to Ilebo, we had to find a way to keep moving. Now, most of the road was ok to drive on. The little indicator on our dashoard learned us that we could keep driving until about 35 degrees tilt angle. It were only occasional patches were the angle would become too big and we'de be on our sides.
We figured that if we would keep enough momentum, that we would slide forward on our side and "bounce back" on our wheels. So, that is what we did. We kept the speed up and if the road dipped too much we would tip over. Because of the higher speed the impact on the side was much bigger. But that, combined with the forward movement created a "jo-jo" effect (do you guys know what a jo-jo is? Not sure if it is called the same in English).
Move forward. Tip over. Slide forward a bit on the side of the car. Bounce back. Wheels touch the ground. Move forward. And repeat.
Some of the longer steep section were maybe 100meter long. We would "bounce" numerous times to get trough this. When we got trough we had a fixed procedure:
- Depending on what side we tipped over, the person sitting on the opposite side would get out of the car first.
- Armed with a hamer and spanner "20" go to the other side of the car
- Bang and bend the door back into shape so it would open again
- Both of us would walk back the part we just "bounced" trough, picking up all the parts of the car that fell of. Usually the mirrors, various bits and pieces of the filling cap, the sandladders, indicator lights and the odd bits of our roofrack.
Strong car!
This technique is probably not described in any "4x4 driving techniques" handbook.  ?
