2003 Giant VT One $500
Nightkrawler
2003 VT One, SOLD
Brand Giant
Component Group Mountain Mix
Fork Rock Shox Psylo Race, 3.00" - 5.00" adjustable travel
Frame Material Aluminum
Hubs Mavic Crossmax UST
Rims Mavic Crossmax UST Disc
Suspension Full Suspension
Tires 26 x 2.25" Kenda Navegal with Stan's Tubeless
Type Mountain
General Information
Colors: Elite Silver
Model: VT 1
Suggested Retail Price: 3000.00
Weight: Unspecified
Year: 2003
Brakes
Brake Levers: Hayes Hydraulic Disc
Brakeset: Hayes Hydraulic Disc brakes, Hayes Hydraulic Disc levers
Front Brake: Hayes Hydraulic Disc
Front Brake Lever: Hayes Hydraulic Disc
Rear Brake: Hayes Hydraulic Disc
Rear Brake Lever: Hayes Hydraulic Disc
Components
Bottom Bracket: Race Face ISIS SRX, 113mm spindle
Bottom Bracket Shell Width: 68mm English
Bottom Bracket Spindle Length: 113mm
Chain: Shimano CN-HG73, 1/2 x 3/32"
Chain Size: 1/2 x 3/32"
Chainrings: 22/32/44
Crankset: Race Face Turbine Lite, 22/32/44 teeth
Front Derailleur: Shimano Deore XT, top-pull/clamp-on 35.0mm
Front Derailleur Type: top-pull/clamp-on 35.0mm
Handlebar: Race Face AM bars with lock on grips
Handlebar Extensions: Not included
Handlebar Stem: Race Face AM 50mm stem
Head Tube Angle: 70.0
Headset: 1 1/8" threadless FSA integrated
Headset Diameter: 1 1/8" threadless
Largest Rear Cog: 34
Number of Rear Cogs: 9-speed
Pedals: Shimano SPD
Rear Cogs: 9-speed, 11 - 34 teeth
Rear Derailleur: Shimano Deore XT SGS
Rear Shock: Answer Manitou Swinger Air, 5.0" - 5.75" adjustable travel
Rear Shock Travel: 5.0" - 5.75" adjustable travel
Saddle: WTB Speed V
Seat Post Diameter: 27.2mm
Seat Tube Angle: 72.5
Seatpost: Titec X-Wing, 27.2mm diameter
Shift Levers: Shimano Deore XT RapidFire SL
Smallest Rear Cog: 11
Fork and Suspension
Fork Crown: single
Fork Material: aluminum/magnesium, single crown
Fork Travel: 3.00" - 5.00" adjustable travel
Frame
Frame Angles: 70.0 head, 72.5 seat
Frame Construction: TIG-welded
Frame Tubing Material: Aluxx SL aluminum
Geometry
Chainstay Length: 16.9"
Fork Rake: Unspecified
Top Tube Length: 23.2"
Wheelbase: 42.8"
Wheels and Hubs
Front Hub: Mavic Crossmax UST
Front Rim: Mavic Crossmax UST Disc
Front Tire: Hutchinson Scorpion Tubeless
Front Tire Size: 26 x 2.00"
Rear Hub: Mavic Crossmax UST
Rear Rim: Mavic Crossmax UST Disc
Rear Tire: 2.25 Kenda Navegal with Stan's tubeless kit
Rear Tire Size: 26 x 2.00"
Spoke Brand: Mavic Zicral
Spoke Gauge: Unspecified
Spoke Holes: 24-hole
Spoke Material: Zicral
Spoke Nipples: Unspecified
Spoke Type: bladed
More Information
Details: Frame Construction TIG-welded
Available Sizes: 16.5", 18.5", 20.5", 21.5"
Fork: Rock Shox Psylo Race, 3.00" - 5.00" adjustable travel:
ComponentGroup: Mountain Mix:
Rims: Mavic Crossmax UST Disc
5307492
ask $500 paypal plus shipping
Have many extras fro the right buyer.
yubert
2003 VT One,
Where are you located and do I understand correctly, you have four (4) different sizes of this bike for sale?
Nightkrawler
Giant is Sold
Did have 4, down to just the KHS lucky7. I have a small bike problem seems I need to own more and more. :Wow1:
Nightkrawler
[/IMG]
The unanimous freeride hit of 2009! \"With the Lucky 7 the steeper the better!\" -Decline Magazine. Designed using the Specialized Brand patented Horst Link suspension system for unsurpassed performance.
Adrenaline build kit includes:
Frame: New Design AL6061, 4-bar Horst bearing linkage, 7.3\" travel
Fork: Marzocchi 66RCV, 180mm, rebound & compression adjust
Headset: FSA Pig, 1-1/8\" Threadless
Rims: WTBSpeed Disc XL, Doublewall
Hubs: Front: Formula Disc, Sealed Bearing, 20mm through axle
Rear: Cassette 12mm x 150mm
Tires: WTB Prowler MX 26x2.5, Kevlar bead, 60TPI
Front Derailleur: Shimano SLX
Rear Derailleur: Sram X-7
Shifters: SRAM X-7 Trigger
Chain: KMC Z9000 w/Missing Link
Crankset: Truvativ Hussefelt w/guard, 36/24t, 175mm
Bottom Bracket: Truvativ Howitzer outboard bearing splined
Cassette: SRAM PG950, 11-34 9-Speed
Pedals: Alloy platform w/crmo axles & replaceable pins
Seatpost: Truvativ XR
Saddle: WTB Pure V Comp
Handlebar: Truvativ Hussefelt, 31.8
Stem: Truvativ Hussefelt, 50mm
Grips: WTB WeirWolf dual density
Brake Levers: Hayes Stroker Trail
Brakes: Hayes Stroker Trail, 8\" rotors
Color: Gloss White
DanoWall
