Built '95 Discovery
Viggen
Just here...
1995 Land Rover Discovery
158,xxx miles
3.9 (good lower mileage used motor) that runs great
- Mean Green gear reduction starter
A/C and Heat work great
Auto trans replaced at the same time as the motor
Safari Gard 3 Link w/ Terraflex center link
Rovertym 3” Springs
Rovertym 1” pucks
Safari Gard Sliders (stripped, POR15'd and painted with hammered finish)
Fox 2.0 Emulsion shocks (revalved for the 3 link set up)
Extended shock mounts, front and rear
Rovertracks Rear Links
Rovertym HD Steering Linkage
Detroit Locker Rear
Rear Diff gaurd
Rear Diff Pinion Slider
SD Style rack
- 6 Hella 4000s front, 2 Hella FF50s (Small oval ones) rear, Hi Lift mount, CB antenna mount, Limb lifter tabs
16” D1 Steel wheels
- 255/85 BFG MTs (about 50-60% tread with like new spare)
Adapter to allow for 255/85 spare to be mounted on the rear door
ARB Front Bumper with reinforced recovery points and limb lifter tabs
Warn M8000 Winch
Great Basin Rover HD Front Drive Shaft
Rotoflex Conversion
No Loss Valve Stems
Removed small section of rear seat for extra storage
Custom wooden floor in the load area with 4 flanges to tie gear down (covered in tan carpet)
- Makes mounting things to the floor very easy
LR Genuine Ladder
D2 Cupholders
Safari Snorkel
Perfect Switch Power Gate Dual Battery Setup
- Optima Yellow Top 2nd battery
D2 Headlamps w/ City Lights
Hood Black Out applique
Sony CD/ Sat/ Bluetooth/ HD Radio head unit w/ amp under rear seat
New Door seals all around, including the rear hatch
Box of spares (fuel filter kit, serp. belt, couple other things it doesnt need but I carry just in case)
Aux Fuse box under dash for lamps (fully powered)
Blue Sea box in cargo area for other things (fully powered)
Columbia Overland black rear door panel with fold down butcher block table
New Transmission cooler lines
Land Rover rubber floor mats front and rear
Extended brake hoses, front and rear
The Good: Great off road and on the road. Lots of work done recently (front pads, new rear calipers, rear pads, rear rotors, rear wheel bearings and seals, ignition module, fuel tank, fuel pump and relay, handbrake shoes and adjuster, rear transfer case output seal and flange). Motor replaced with a lower mileage used one and it runs very strong. Passed emissions and safety inspection. All windows and door locks work. Alarm ECU replaced so everything works. New distributor less than 6 months ago. Neither of the front seats are torn but they are well worn.
The Bad: Has rust but less than the usual by far. Nothing too major and confined to the drivers floor. It is not a hole but more like a crack where the two parts of the floor come together. Could be easily patched from underneath with a flat piece of metal. Other than that, its solid. The drivers seat bracket has a hole/ ear rusted away so the drivers seat is attached to the floor by three out of the 4 bolts. Drivers seat no longer adjusts (switch issue). Front windshield wipe/ wash no longer works. I installed new relays but its either the actual switch or the MFU (BRAND NEW IN BOX ones of each are included). Just havent had the time to install one or the other to fix the problem. Faded paint and some pinstripping. Headliner sags a little bit (normal for just about every D1). Some paint sun burn.
Im selling as I am buying a D90. No other reason than that. Its been a great truck. Ive caught up on all the maintenance and attend to everything. Just did an oil and filter change along with trans flush and fill and new fluid in the diffs and transfer case. Great driver and even better off road.
Pictures: Look at my sig down below. More available if needed.
Viggen
Just here...
Haha, I suppose the price would help: $6300 obo. Couldnt build a truck like this at that price.
Viggen
Just here...
Taking it off the market for now. Need to fix a newly emerged issue. Thanks for all the comments on it. Theres a stock one for sale for $3k here and that extra $3k for mine wont build a truck anywhere close.
taz223
ExplorationOutfitters.com
Lemme know when you get the "issue" resolved, I'm interested. Where are you located?
Viggen
Just here...
Like Axe said, Im in Northern Va. The issue turned out to be a a bad u joint in the Great Basin front shaft. Ill get the new one installed shortly and then itll be up again. If youre serious, PM me and I can tell you all about it.
Viggen
Just here...
Rebuilt (completely stripped, painted, balanced, 3 new joints and replacement cardon piece) Great Basin shaft installed along with front calipers. Now it has a completely new/ refreshed brake system. Also included are the Ashcrofts HD rear shafts I installed when I redid the rear axle. Looking to sell. If youre interested, hit me up.
Interior shots:
(Green things are limb lifters)
PNWav
