1992 Montero LS -NEW OWNER!
mnutz
Coolant Flush and more fun stuff!
Did the coolant flush this afternoon. The fluid I got out was BAD, looked really dark. The thermostat was stuck open, I could not physically make it close all the way. Installed new thermostat, new rad cap and hoses, filled coolant back up. Now I got hot heat! Plenty of it! Bad news, the overflow tubes were completely plugged with greasy gunk. I cleaned everything out, then realized the coolant I was seeing on top of the radiator... well, the radiator is split open along the top seam. Not sure what to think now...
off-roader
You can have the radiator fixed for a relatively inexpensive amount. Having it rodded for ex. would be no more than $300 and that's here in Ca. where the environmental fees will raise the cost tremendously. Alternatively you can buy a used one in good condition on car-part.com for cheap too.
Grease/oil in the overflow is troubling. Possibly a head gasket issue sometime in the past. Do you know the engine history? If not immediately ask the seller. At this point you prob can't return it but you can at least learn what to expect in the future.
mnutz
Update...
Well, the truck is running great since the coolant flush. No new problems have sprung up and I've been wheelin' it a lot.
Haven't been able to make much sense out of the previous owners history report. He says that last year it stopped running completely, wouldn't start. He was gonna get rid of it as the miles were really high (200k+) and he'd had it a long time. A friend of a friend turned him on to a mechanic friend, and he says he replaced the crankshaft?! And it's run great since. Hmmm, I don't know about all that... but like I said it runs strong and nice. Still does the intermittant no-start thing, maybe every 5th time I try to start it, but I just back off the key and it always starts right up the 2nd try. The start is instant and snappy, sounds great, idles great. A little whitish smoke at start-up, even on warmer days, but the smoke goes away as soon as the engine gets up to temp. Coolant is staying clean since the flush, its got a couple little oil leaks though, not serious ones. I'll sort those out in the spring cause I don't have a garage and it is COLD here! Mechanically and electric wise it all seems solid.
The heater blower motor makes a terrible racket, and it seems like the lever for fresh air/re-circulate does nothing, I think it stuck in the fresh air mode. My defrost is super hot, but the vent air is not quite as hot. The radiator does have that small leak on the top tank seam, I've seen replacements with metal tanks as low as $140.
All in all I'm very happy, I think it'll be great to start upgrading this spring. First in line is a t-bar crank and some 33x10.5 BFG KM2s. I hate to have to buy new wheels, I wonder if those alloys are actually 6.5", and I could squeeze 10.5s on 'em?
off-roader
Good to hear that.
Ask who the mechanic was. Say you'd like to replace the radiator. Then find out from the mechanic what was really done. The crankshaft replacement would be a major piece of work and frankly I rarely hear of them going bad. In fact your story is the first one I've heard of having to replace one. It is possible the owner didn't remember exactly what was replaced.
Experienced that before. 2x. 1st was a bad starter (brushes needed to be replaced). 2nd was a bad ignition switch.
Do this. When it's warmed up, like after a 15-20 min. drive, park the car with the engine running. Let it idle for 5 minutes. Do nothing to the gas pedal. Just let it idle. After 5, rev the engine. IF smoke billows from the tailpipe, you have bad valve guide seals. Can be replaced without having to do the valves (they're usually good and won't need replacing anyway) using the LP Air or Rope trick. Cost is usually around $700. You don't have to do this but it will coat your catalytic converter and make it inoperable. This may impact any smog testing thats required by your state.
yup. My forecast tells me you'll be tearing into your hvac system soon to fix that or will simply learn to put up with it.
I prefer OEM replacements myself and would consider a used one from car-part.com before buying a new non-oem one but that's just me. :)
They will & others I know run them but BFG recommends a 7-9" wide rim. Most shops will not mount them due to liability issues.
David Harris
Actually it's a more common problem than you would think on these motors. There's a design flaw in the harmonic balancer which eventually ruins the crankshaft snout. I had a 1994 Montero with this problem. Had chronic problems with it and finally broke down on a trip to the Grand Canyon in it and paid 1000.00 to have it fixed, temporarily. The dealer told me that the crank snout was bent and the whole thing would have to be replaced eventually. So, I ended up selling the truck.
David
mnutz
David
This is similar to what the previous owner told me, that when it happened his estimate was $2500 for the repair, but he found someone to do it in his driveway for much less.
I guess time will tell, but it all seems good right now anyway!
mnutz
Yeah, I'm trying to find out how to contact the mechanic.
Hope it's the ignition switch!
We don't have smog testing here in the great state of Nebraska!
I don't think I can put up with it, wish I had a garage! It's cold out!
Thanks for all your input off-roader! I've followed your posts here and on the wire, you've got a lot of Mitsu knowledge!
tanglefoot
ExPoseur
On the wheel width, I have run 31x10.50 tires on 15x6 wheels for quite a while. I love the look and the handling, have had no troubles, and the tire shop never mentioned a thing.
Eric
mnutz
Eric
That's great to hear! I agree the wheel/tire combo on your rig does look good!
