New project
PAToyota
Ah, kept looking to try to figure out how it worked. Finally noticed the picture with the actuators. Very sweet work!
dsw4x4
Another question - if a van already has a high top, can it be converted to the pop up still of do the holes from the original high top install cause leaks? Is it best to not install the high top until the pop top is to be done? And whats the cost difference between the do it yourself kit version vs. driving it there to have you perofrm the install?
This can be tricky, if it is a reverse flange top you can reuse the top by cutting off the flange and filing the screw holes on the van. (usually there are very few holes with this style) The problem becomes with trying to remove this style top it is glued down using some really good glue all the way around the top, removing this takes a lot of effort/strength, patientice, and some long sharp knives to not screw up the top or the van roof. If you are using a reverse flange where the screws are every three inches all the way around the rain gutter you will have to go back and weld all of those holes closed after you remove the top and begin building the poptop to otherwise leaks will be inevitable. I would say yes you are better off to not install anything until you decide on your final top. You will spend way to much time and money trying to do it twice to make a usable the first time then tear it apart to do it the second time. However if your van already has a raised roof it can be converted (probably cheaper than buying a new one) it just depends how it is attached. To build a poptop yourself you can expect to spend 2k to 3.5k depending how crafty you are at sourcing parts and scoring a cheap top plus your time. So far the average do it your self time I have seen is 4 to 6 months of night and weekends for a normal working joe with a family. My normal tops are 5500 this is the normal price for a top like you see in this build using a new top and single wall canvas (triple wall is extra) includes 6 led lights finished head liner power lift and a bed. Painted to match is extra.
RocKrawler
Supporting Sponsor
Thanks for the reply, gives me a good idea of how much to budget for the setup if I go poptop. I'm plenty crafty and can source things plenty cheap with my connections so that isnt an issue, just have to figure out which way the wife can be led. I'd personally prefer the fixed megatop for simplicity and price, and stealth factor when on the road (it will be abundantly apparent whats going on with a pop top deployed in a parking lot or rest stop as opposed to a fixed top just sitting there).
18seeds
The interior of the van and a complete open canvas. A bed can be easily added later. There will be enough headroom to sit up in the bed without hitting your head.
RocKrawler
Supporting Sponsor
I'm liking the pop-up Terry...
I like the idea and "bling" factor of the pop-up, but the added expense and potential issues (both mechanical of the lift linkage & mechanism and wear/tear of the fabric) concern me in the long term. The wife gave the green light on the fixed top based on the pics of CCV's other post with the high top & 8" dropped bunk as long as we add the windows as shown, so the hunt will be on for the donor top. I think it will be the best option for us and our current budget, and if need be it can always be converted over with a little extra work if needed after the u-joint conversion if we feel we have to go the pop up route after all, but I doubt it.
evilram
any pictures of the intererior with the top down? With that much of a pop-top I am interested in how cleanly all the fabric "folds" away.
18seeds
evilram.... i'm in Littleton (Old Town) if you ever want to check it out let me know.
My vertically challenged friends can almost stand up in it.
18seeds
This gives you an idea of the overall height.
van is sitting on 33's
tundra is sitting on 34's with a small lift
Lockwoodjd
