Cheap 800W 4-stroke inverter generator
teotwaki
Excelsior!
http://www.amazon.com/IN800I-Gas-Po...f=sr_1_23?ie=UTF8&s=hi&qid=1267983270&sr=8-23
I saw one of these at the Orvacs Electronics store in Fullerton, CA. It was not quite a Yamaha clone but was definitely Yamaha "inspired". Fit and finish seemed fine. It is so cheap I was tempted even though I don't need one.
teotwaki
Excelsior!
A whole bunch of bargain models at Eastern Tool (funny name for selling Chinese clone generators!)
[ame="http://www.amazon.com/s/ref=bl_sr_hi?_encoding=UTF8&node=228013&field-brandtextbin=Eastern%20Tools%20%26%20Equipment"]Amazon.com: Eastern Tools & Equipment Home Improvement[/ame]
3500 Watts for $850
Product Features
  1. 3000 watt rated/3500 watt max output
  2. Computer control pure sinewave alternator with THD under 3%
  3. Operates at a quiet 60 DB
  4. Will run for 5 hours with 1/2 power load
  5. Non-CARB Compliant/Not For Sale In California
dwh
Tail-End Charlie
Neither of those links work...
I have a Honeywell H2000i and after having two replaced under warranty, they finally sent me one of the 2nd generation 2010 units which works fine but takes a lot of pulls on the rope to get started.
I think the hot ticket for inverter gens for the next little while is going to be the new Champion:
http://www.championpowerequipment.com/73531i.php
Basically equivalent to the Honda or Yamaha and it's the first lowbuck inverter gen that can double up (connect 2 together) and have the inverters sync like the Honda or Yamaha.
Has an 80cc engine, same size as the Yamaha (Honda is 100cc) and has the same 1600w continuous, 2000w surge rating as the H and Y.
Pretty much the same run time - around 10 hours on a gallon at 400w load.
Going for about 500 bucks if you can find them. They are also producing the same unit in black and silver under the name "Category 5":
http://www.northerntool.com/shop/tools/product_200458014_200458014
Champion has a good rep on the RV forums.
D
Deleted member 9101
Guest
they have a 1,000 watt coleman at biglots for 160.00
teotwaki
Excelsior!
good additional info!
The forum is somehow mangling the links. If you do a quote of my message and extract the actual www link it will work or just search at Amazon for generators at Eastern Tool
mudbutt
800 watts is'nt very much power.
I bought a 1200 watt at Kragen a few years back. On sale and with rebate it was $99.
But even 1200w will only run 1 of those hologen work stand type light set-ups.
I think it was before the ban tho. It's a 2 stroke, loud and smelly.
It's on the shelf with my earthquake supplies and only gets fired every other month for testing now as my RV has a 55 kv genset.
dhuss
