Looking for Leveled Super Duty Ford owners
What size tire did you put on your leveled Superduty?
  • Total voters
    25
Greggk
ZombieSoldier
specifically 1999-2004 with the leaf springs. when you got done leveling it, did you use 285's, 305's, or 315's? is there any rubbing? how did it effect the fuel economy? PICTURES PLEASE :)
shock
I had 285 and went to a 305 and it doesnt rub anywhere. I havent noticed any fuel issues ai all. W,ith the new wheels and tires not the black anymore
lllateralus
Here is my 2001 F350 7.3 liter, 3" leveling kit and 1" additional block in the rear.
Running 315 75-16's BFG All Terrains.
toddz69
When I got my truck, it had 315s on it with ~4.5" National leafs on the front. I took those off and replaced them with a 3" Donahoe Racing (now Icon) leveling kit with stock springs and went with 285s. My mileage decreased (yes, the speedo was cal'd correctly for each tire size) when I went to the 285s. I attribute it to ~200 rpm higher engine speed at highway speeds.
Todd Z.
lllateralus
Greggk, yeah the factory block has a 1" block on top.
It was like that from the previous owner. I have contemplated removing it, but have not gotten around to it.
No ill effects....
Humvette
Yeah i want to level my dually and run 35's front and rear :wings:
I know it will hurt my arround town and towing mpg a lil, but unloaded highway it should help because of the bigger diameter.
M
lllateralus
Thanks Silverado!!
Shes a wild one, 720cc big bore, ported head, Web camshafts, +1mm oversized valves, big carb and full exhaust, Ron Woods CDI
Fun bike!
SLO_F-250
Here's a picture of mine. Shes a 99 leveled with 285/75's on the stock rims. I really like the stance. I still get 18mpg on the freeway cruising around 67mph. 15mpg around town.
When I get another set of tires, I might go 305/75's, but am not sure. I would expect that the mpgs would drop slightly again. You can fit 35's with the leveling kit no problem, just depends on what you want. More pictures can be found on the link in my sig.
Mike S
Sponsor - AutoHomeUSA
I am running 285/75/R16 Toyo M55s right now. Getting 19 MPG highway. Will probably go to 255/85/R16 M55s and see if this bumps my mileage a bit. The F350 is 'leveled'.
gp01
