Spring Isolators
Howski
After installing my winch, the front end of my DII started to sag slightly. I am considering getting isolators to raise it back up a little. I am unsure whether or not to put them on just the top or on both top and bottom. How much of a boost does an isolator usually give?
leeawalden
Man, I've never really measured them, I would guess around a half inch tops. why not just get a set of 1" spring spacers? How much sag you talkin?
Howski
I'd say 1/2" or 3/4". It was perfectly level before the winch with DI spring seats and a pair of isolators in the rear. It's not bad enough where I'd need to move to a 1" spacer.
leeawalden
Id go ahead and buy 4 of them, enough to the the top and bottom, if you don't use them, you can just throw them in a drawer or box...the fall apart over time.
leeawalden
I'd call Will, Marty, PT, or Paul, (any of the part guys) and see if they have any used ones in good shape, if not Atlantic British has them. I only say spacers because You could buy a set of spacers cheaper than a bunch of the isolators...new anyways.
iStan814
