Light Bar?
Silverwulf
Anyone here have lights on their roof rack or roof light bar? I have been thinking about it but want more info on the wiring.
Do you REALLY have to drill a hole in a perfectly good roof to run the wires to the lights?
:yikes:
:yikes:
Like this? These are some OEM Mitsubishi Offroad lights mounted on a Defender 48x24x4 roof rack. The roof rack has 4 mounting tabs in the front for offroad lights and 2 additional tabs on the rear of the rack for whatever. I have these lights wired to a switch in my cab from www.otrattw.com
ColinTheCop
When I had roof lights I ran the wires down the windscreen pillar, into the engine compartment and through the bulkhead.
I just taped them to the piller with black duck tape. It looked neat enough and worked well.
Like you, I couldn't face drilling a hole.
Silverwulf
Cool PUP.
I was thinking the same as far as running the wiring down the A pillar. But what about rear facing lights?
off-roader
Assuming they'll be mounted to some sort of rack, just run the cables along the length to the rack to the front.
Use those rain gutters to your advantage.:ylsmoke:
I also like the black tape idea.
On my Gen I have had rearward facing fog pattern lamps (Hella Micro FF) and used a standard trailer wiring harness spliced into the lights. When not in use (on road), I simply unpluged the power wires and kept them in back. When in use, I simply ran out the rear door and plugged them into the female connector (with an integrated cover) at the light.
Also, instead of using the normal/common split wire loom to sheath the wires, I instead used a braided plastic wiring loom on the wires. This way, it still helped to protect them from any possible abrasion while allowing any water to drain instead of collect.:ylsmoke:
HTH.
Silverwulf
"I instead used a braided plastic wiring loom on the wires. This way, it still helped to protect them from any possible abrasion while allowing any water to drain instead of collect. "
I was thinking of doing the same thing. I think the split conduit is a good way to introduce moisture into the cabin on wet days. The braided stuff will let the h2o escape prior to cabin entry.
4xCoffee
