RTE Suspension Swap
X-plorenow
I currently have a 99 DII with an RTE 2" suspension lift with a 1" spacer. The engine is blown and I want to swap it over to my 04 DII. Are there any issues with this swap? I believe RTE markets two different products, one specifically for the 03 and 04's.
Thanks,
Mike
Fivespddisco
Supporting Sponsor
Thanks,
Mike
Mike
It will bolt right in, it is the same for all D2s. If you have a RTE panhard it will not work for some reason Rover changed the bar on the 03/04s
dallas
What other mods did you have to do to fit the 1" spacer, basically giving you a 3" lift. I have the OME 2" lift and would not mind getting the spacer. Do you have more wander at hwy speeds? any problem with brake and abs lines or do the shocks limit downward travel?
zhukoveli
