National Luna: Kit vs. Component Cost
YukonRob
Looking at the National Luna kit and trying to justify the cost of the kit versus buying the key components and sourcing the remaining parts locally.
The turn-key kit is advertised for $375
The solenoid is $145 and the monitor is $70.
Add wire (±$60), connectors, fuses, misc, (±$25) and I am at $300.
Is there something in the kit, aside from the convenience factor, that would justify the additional $75? Or am I off on the costs of the locally sourced items?
Thanks,
Rob
Herbie
Rendezvous Conspirator
I would budget more than $25 for the fuses, etc. to do it "right", but those are not items included in the National Luna kit either, so I think your math is probably correct.
Incidentally, for (relatively) inexpensive thick cabling, I chop up jumper cables. Autozone had 20ft 2-gauge cables (40 ft of cable total) for $45 or $49. Very flexible and you have the option of splitting or not-splitting the pair. Thinner cable will obviously be even cheaper.
tperkins
Herbie, I have to say thanks for that tip. And to the OP, I was thinking this exact same thing in my head the other day. With how expensive dual-batt kits are, saving $50 or so is a good deal.
1leglance
Having just installed a National Luna Kit I have to say it was really really nice to have EVERYTHING I could need (and some extra bits) all at hand.
The bits are top notch and there is far more cable that you will need, enough to run a battery to the back of the average rig.
It comes with a 3 fuse setups and was super simple to install cleanly.
Utah KJ
Free State of Florida
I've looked at the kits and in my professional opinion, I feel that the wire gauge is not sufficient in those kits. I good source for inexpensive cable is a welding supply store.
cruiseroutfit
I'm taking my stickers back ;)
The wiring is adequate for close proximity installs, i.e. both batteries are close and the Intelligent Solenoid is right close as well. However if you've got long runs, I would up the size a bit and in that case the components make more sense than the kit. Depending on the type of install you do (National Luna has several recommended setups for example) you might not use the fuses in the kit, thus making the components the better choice there too.
I'm running the full kit on my Tacoma sans fuses and its been flawless, eventually I plan to add a kit to my Cruiser and in that case I'll part it out.
TreeTopFlyer
I went piecemeal because I was doing a 3rd battery and the provided cable wasn't long enough, I wanted a Bussmann disconnect, and still haven't decided if I want the monitor. I may pick one up down the line if I find one cheap.
tperkins
For those that own a Nat Luna kit, how many feet of cable, and what gauge, does it come with. I can't find anywhere that says it.
Kind of off topic, but should it be okay to run two different batteries in a dual charge setup, such as one lead acid starting and one AGM deep cycle?
flyingwil
IIRC, The National Luna comes with 20' of silicone core cable (10' each, Black & Red).
I would also consider the IBS dual battery systems. I swapped over to the IBS from my National Luna a few years ago and haven't had a complaint on the system since the swap.
keezer37
I've been running a lead acid as the primary and AGM as a backup for about five years now. I'd rather have both AGMs for my setup but the gods conspired against me when I replaced the primary three years back.
bob280zx
IBS/Luna
More hijack!
I've narrowed it to a choice between Luna and IBS - just can't decide. If you don't mind, why did you elect to change to IBS?
Thanks
DFWSFO
