Next uprade for Explorer 1
Explorer 1
Explorer 1
The "Beast" has arrived.......
The axle housing was ready even though the RCV axles haven't arrived, so I opted for taking the axle home and starting the process of seeing how well it fits.
That pumpklin looks so large I'm beginning to wonder how many other modifications I'm going to need to make so it doesn't hit anything.
More later....
Thanks,
Fred
Explorer 1
reece146
Automotive Artist
Fred, I think you better really check how much clearance there is between the differential housing and the oil pan at full bump.
If I remember correctly you are not running a lot of lift or long bump stops and that housing appears to encroach more to the centre line than what I remember what a Dana 30/44 does.
Funny, nothing like a dig differential housing to show just how narrow/small a Jeep ~OEM width axle housing really is...
Dig it.
Keep us posted.
Explorer 1
Explorer 1
Have you been reading my mail?
Dig it.
Keep us posted.
We will see...........My thoughts exactly.
Thanks,
Fred
Explorer 1
StumpXJ
SE Expedition Society
More later....
Thanks,
Fred
Explorer 1
Green with envy sir....
~ Stump
Explorer 1
Explorer 1
So far, so good.........
Once I pulled out the Dana 30 I was amazed how small it looked:
I'll need to cycle it through to see if I need to adjust the Acos or modify the bump stops. So far it fits in fine.
More later,
Thanks,
Fred
Explorer 1
Explorer 1
Explorer 1
A little too close for comfort?????
Cycled through the suspension today and first off the engine and trans skid plate is going to need to be slightly modified (corner cut off).
Next, as I suspected, I'm going to need a custom down pipe/collector on the header:
Third, I was surprised that the oil pan didn't hit but how close is too close???? :Wow1:
The skid plate can wait, the header will have to be dealt with first and I'm still deciding on the oil pan.
Thanks,
Fred
Explorer 1
reece146
Automotive Artist
Between flex in your arms and compression in your bushings I would like to see more space between the differential housing and the oil pan. Are you running stock length bump stops?
Explorer 1
Explorer 1
Bump Stops
The Bump stops with the rubber cushion are 5". This is a full flex with the ACOS adjusted adding 1" of lift.
Thanks,
Fred
Explorer 1
Bigjerm
I know pictures can make things look funny but it kinda looks like the front axle needs to go forward some.
Explorer 1
Explorer 1
Yep, needs some adjuctment
Your right, the LCA & UCA's need some adjustment. Off come the springs and time to adjust the length.
Thanks,
Fred
Explorer 1
K2ZJ
That looks better, the axle will swing forward when it flexes and line up fine. But, your caster looks off... :eek:
Explorer 1
Explorer 1
The Orange Globes are in.....
Just about done, here they are after we had to shorten the short side to fit:
Maybe tomorrow a test drive.....
Thanks,
Fred
Explorer 1
zhukoveli
