JeepFreak21
I'm building an M416 clone - 14 gauge sheet metal tub, 2" x 3" x .120" wall box tube frame - my question is, is it ok to hard mount the tub directly on top of the frame or should I use some kind of insulating washers/bushings in between the tub and frame? It will have a coupler that looks a lot like the Max Coupler and an independent trailing arm suspension on air bags, so I can't imagine there could be much twisting/tweaking of the frame outside of the weight of the load. If you recommend bushings, what properties would you suggest?
Thanks a bunch,
Billy
Thanks a bunch,
Billy
