Grumpy the Astro van - One man's delusions, a love story.
ihatemybike
This is what I spent my weekend doing.
Saturday remove rear axle and disconnect lift spring shackles from body.
Sunday remove shackles from springs. Whole afternoon spent on to freakin bolts, argh.
Ozarker
Aaron, looks to me like something is missing! Just had a feeling you didn't live in such a bad area.....:sombrero:
ihatemybike
Two very good reasons. Lift shackles and limited slip.
No progress made today, can't get the lower shackle bolts I need locally. Heading to a McMaster-Carr distribution center tomorrow.
I did position the limited slip axle under the van and mount wheels to it, but that's only to keep local code enforcement from bothering me.
RocKrawler
Supporting Sponsor
Paging tlow and herbie... Please come to the information desk immediately.
Sent from my HTC Thunderbolt.
Herbie
Rendezvous Conspirator
Hehe, don't think I can answer this one. I don't have the G80. As for how strong, well the ring & pinion should be the same as the regular 7-5/8" rear, so it will not be any stronger than the regular astro "soccer duty" axle.
T.Low had an aftermarket Eaton locker for a while, I think, and eventually blew it up. Not sure if the failure was because it was "weak" or because he put it through some serious use.
For myself, when I get to the point of needing a locker, I'm looking into whether or not I can fit a 12-bolt/14-bolt from a fullsize van so that I can have a selectable locker. With the van's passenger-side offset and relatively wide width, not just any axle will fix under there.
Bummer about spending so much time on the shackle bolts, though!
RocKrawler
Supporting Sponsor
Toyota FZJ80 axle is 6 lug, wide, passenger offset and available with factory electric locker. Contemplating it for mine pending measurements but.then would have to swap front to same bolt pattern.
Edit: quick research online says the astro has a 62.5" rear width, and the fj80 is about 63.5, so about 1/2" wider per side
Herbie
Interesting about the FZJ80 rearend. :Wow1: Disc or drums?
Not sure it'll be any easier to find, but work keeping an eye out for...
RocKrawler
Supporting Sponsor
9.25" ring gear, full floating axles, disc brakes on 93 & newer, drop out center section, and same six lug pattern. Electric lockers were an option but not too difficult to find. Another thing I was thinking about is adapting the transfer case from one as well. Has Awd with viscous coupler for snow and an optional center diff lock to turn the Awd to 4wd, and it has a decent low range as is with aftermarket lower gears available too.
Sent f rom my HTC Thunderbolt.
