eXpeditionXterra Build Up
TeleScooby
All I can do is echo again...wow, that's one amazing rig!
Can I make a photo request? Some overview shots, side on, front quarter, etc...I really want to see that bad boys stance, how the overall set up affects the look...
Thanks and keep us updated!
offroadchef
inspirational build....
eXpeditionXterra said:
Rear cargo work is getting farther along. Aluminum deck is line-Xed drawer and other components powder coated with a hammered finish to match the Line-X.
The drawer was power coated in a reflective silver.
The 2150 house battery hold down also got a hammered finish.
Is that square tube on the drawer slide for the stove or somthing else? I read very post and did not find a answer....
eXpeditionXterra
Well, as I suspected GOBI has produced a rock solid rack system for the Xterra!
Installed:
-GOBI Ranger (now called Hybrid) roof rack
-GOBI Axe/Shovel mount
-GOBI Pull-Pal Mount
-GOBI Rear Ladder (right side mount)
-Custom Lightbar (the GOBI one wouldn't work for the WARN lights used)
-Custom tent mounts w/accessory holes
-Custom side light mounts
-4X WARN dual mode lights
-2X PIAA 1500XT Sides
-2X PIAA 1500XT Rear
And the finished product:
eXpeditionXterra
Tripple battery monitoring system.
Will display charge status while driving, and can check voltage level while stopped.
Willman
First class build my friend!!!
Keep the pictures and mods coming!!!!!
Getter er' done!!!!!!!!!!!
:jumping:
BajaTaco
Swashbuckler
I must say, I am blown away :drool:
I have seen some cool Xterras, but man...
Congrats on a job well done.
eXpeditionXterra
KevinNY said:
How are the stock axles and CV's in these?
Rear diff is an H233B Way overkill axle for the Xterra. The thing is huge!
The front Diff is sturdy, the weak points are the Hubs and CV's. Been wheeling it HARD for three years, never broken a half shaft, torn a CV, or exploded an auto hub.
BUT - I carry a spare of each, just in case :)
Super Doody
Hot water shower installed, cables cleaned up, wiring for new alternator installed.
ARB solenoids for front and rear lockers upgraded.
YOur SC nose cone has a darth vader mask...sweet.:)
How do you like the toyo tires?
erin
Have the Jounce bumps made a big difference in handling and bottoming out?
Especially curious how they work with the leaves in the rear.
eXpeditionXterra
Put it this way... I accidentally jumped a 6000+lbs truck and hardly felt it.
The bump stops are amazing.
4xCoffee
