school me on truck campers
mopar
ok so i have never owned a camper, and i am completely new to all of this but i have an idea of what i want, i just dont know where to start
my ideas
i need to be able to tow my 10,000 car trailer with my jeep on it, and i would like to be able to use the factory hitch on my truck
and i would like to have a bathroom with a shower
and i want an all hard side camper with basically all the normal options .... heat, a/c, small cooking area
what should i look for ? and how much should i be looking to spend?
dieselandmud
First, what truck do you plan on using? Details are important, like short or long bed, 3/4 or one ton, etc.
How many adults/kids do you plan on traveling with?
BillTex
One ? I can answer is; if you want to tow off your factory hitch (I assume you mean "no extension") then look at TC's that are no longer than your bed length...if you over hang...you will need a hitch extension.
Post some truck deets and we can hekp you out.
Shorts answer is; yes, you can find something to meet your criteria.
Bill
FishPOET
You want to haul and tow at the same time.
Does your truck have single rear wheels (SRW) or dual rear wheels (DRW)? DRW provide more stability and allow you to haul and tow more weight. DRW struggle on narrow dirt roads and in sandy situations offroad.
IMO know what your trucks capabilities are before you select a camper. The rear tires will dictate the amount of weight you can haul and tow safely.
8' campers are lighter than the longer campers. 8' campers make it much easier to tow heavy trailers. Only a small portion of 8' campers have all the amenities you are looking for (bathroom). If you have a SRW truck you will want to find a 8' camper.
Longer campers really add weight and you need to add special towing hitches (Reese Tow Beast or TorkLift Superhitch) Much of the camper's weight and all the tongue weight (15% of the trailer weight) sit on the rear axle. There are quite a few campers made that are over 4000# and even a DRW struggles with the weight without pulling a trailer.
Truck campers (TCs) are very expensive (per square foot) compared to other types of RVs. TCs are more plentiful out west and probably quite scarce in your part of the country. Used TCs can be found with patience and searching, although it is a much easier task out west.
bajajoaquin
I know that FishPOET just showed that he's willing to do otherwise, but my advice would be to either go for something bigger, or set your comfort sights lower. (Edited to add: looks like his trailer is lots lighter than 10,000 lbs, so he's much more conservative than the scenario I lay out below.)
From memory, the GVWR of my 2003 F350 is 9900 lbs. Since the curb weight is listed as about 5500 lbs, that sounds great. However, that's the curb weight for the stripped-out base model. Mine is an extra-cab with lots of options. Then you get the miscellaneous crap behind my seats, and a driver and a little fuel. My actual driving-around town weight is nearly 7,000 lbs. If you have bigger tires, aftermarket bumpers, etc., you will be higher.
An 8-foot Lance with a bathroom is going to weigh about 2,000 pounds, maybe more. Add in water, propane, food, your family, maybe some bicycles, coolers, etc., and you can easily add 1000 pounds to that total. You're now over your weight limit.
Max towing on a SRW F350 is 11,500 lbs. Tongue weight is supposed to be about 10% of total weight. You're looking at 1,000 pounds on your trailer. Have you weighed your trailer, and tongue weight? When I towed a 27-foot race car hauler, I was really surprised to find out how far off I was in my loading.
Anyway, your 1,000 pounds of tongue weight has now put you over your weight limit by 10%, and you're towing at 90% of rated capacity.
For me, that's not enough margin, especially considering that we're all on an "expedition" forum, talking about going places that are tougher on vehicles than I-40.
Yes, lots of people do it. And you will probably get away with it.
But what if you don't? Where will you be when you have a failure?
TCcruzn
The best way to start is to pick your camper and then find the truck to carry it. Most people, however, have the truck and then work it out.
Check out truckcampermagazine.com, they have alot of info on the different brands. Also RV.net on the truck camper forum for info on truck mods.
By watching the wet weight of the camper and adding the right stuff to your truck, like airbags and a Torklift Superhitch, you should have no problem with a truck camper and a trailer. I tow a 2 horse trailer behind a F250 with my Lance 830 and it handles just fine.
ramsport59
I'm Mopar's buddy who directed him here. He has a 2002 Dodge ram 2500 Cummins Long Bed 4x4. Yes he wants to use the factory hitch without any extensions. I'm gonna guess at 2 people max.
Hopefully he will chime in here soon.
Rick
greg mgm
I've had 8', 8 1/2', 9', and 10 1/2' campers.
The longer ones made it impossible to tow without an extension, and I compensated by getting a Ruenel HD bumper/ hitch combo and used a dual arm extension to tow with. A very HD solution. You mentioned wanting to use your factory hitch, so I'd highly recommend getting either an 8' or 8 1/2 camper. Finding one with a shower will be the key. My 8 1/2' was an older Pilgrim that had a shower. Weight was 1800 dry. I ran Air Lift bags and everything was great. Easy to tow with since it only hung off the back 6", so no extension needed. Another option is a pop up. My 2003 pop up Starcraft 8 1/2 also had a shower and was easy to tow with. 1600 lbs dry.
FishPOET
OK. It is SRW. What are his rear tires rated for? Add the tire ratings of both rear tires. Stay within your rear tire limits and you will be fine.
An 8' hard side camper loaded and ready for camping should be approx 6000 lbs on his rear axle. A weekend wheeler on a trailer might add another 800 lbs of tongue weight. If his tires are rated at 3500 lbs apiece or more he should be good to go.
mopar
sorry everyone, been a few days since i have had the chance to check back in
like ramsport59 said my truck is a 2002 dodge ram 2500, i also have the extra factory camper package with the overload springs.
tires i am running are in the 3200 range
and i exaggerated the trailer, it really only is a 7000lb gvw trailer, but i will be very close to that weight
this is an old picture of when i first bought the jeep and the trailer, since then the tires have changed on my truck to a bgf a/t
and the jeep has grown up ... or is in the process of growing up
RedRocker
I'd stick with a shorter camper, I ran this rig and wouldn't want anything bigger on a pickup truck. Camper weighed around 3K, but did have all the comforts of home in a small package.
tombodad
Not to HiJack, as I think its related:
I have a shortbed (6.5') 2500 diesel. SRW.
I am also interested in hard-sided campers.
Requirements for me would be"
Has to have running water, heat, (a/c would be a plus, but not reqd), bathroom (shower inside would be nice), outside shower.
Am I limited to 8.5' campers because of my shortbed?
How old can I go and find a decent one? My budget is pretty low (no problem with having to do some refurb/cleanup)
Photomike
White Turtle Adventures & Photography
You are not limited to a length as much as weight. I have seen some HUGE units on short beds, honestly I would not want one as they do not look safe.
My TC is a 92 and has everything that you mention without the air (around here the air is not a big issue and I did not want the extra weight of a air unit that I would seldom use), and I do not have an outside shower but for me not a big issue. I do have a long bed as I had the option of buying a truck for the TC so that is something that I decided on, again not a big issue as I see many short beds with TCer's.
The biggest issue for age is to make sure that they are solid. If they have no water damage then age is not a big thing. Water damage will kill a new unit as much as an old unit. Again for me - I went with a Northen Lite as I wanted a lighter unit and I love the fiberglass for being water proof and better in the cold.
iStan814
