LR3 Bump Stop Mods?
So after much consideration. I really want to go with a 32" tire 275/65/18, but defiantly do not want to have a suspension fault and be left on rubbing, stuck.. With no way out.
I dont care if I gotta make it off the trail [or off the road for that matter] low riding. I just want to me able to move.
I hear the LR3 Bumpstops are more of an internal style in the air spring, but Im not sure. Does anyone have any good ideas for a bump stop? Im sure I can figure something..
Mack73
The vast majority of the "on bump stops" that occur are software related. An incorrect signal (failed height sensor) or other electronic fault causes the system to shut down to prevent it from damaging itself. Rarely does the hardware fail. (Well expect the recent events relating to control arms contacting the airbags).
First you need to understand the system and the failure points to come up with a solution for each type. But to quickly answer your question, the only reasonable way to get at the internal bump stop would be to attempt to cut off the bag and wedge something in there, but you'd need to do this for all 4 bags and that equals over a thousand dollars of new airbags.
So for software related issues, a faultmate can help you reset the system to get it to start up again. If the system has failed and you still have air in the bags, you can pull a couple fuses to shut down the release valves from opening, thus keeping you up until you can get off the trail.
Assuming the bags, lines and valves are fine (which is a lot of the time) - I am in contact with a company in Australia which is in the final testing stages of an "emergency air up" kit. This involves placing some valves in line for each airbag. If the main compressor or software fails, you can use a small external compressor to manually inflate each bag. I have a thread running on www.lrrforums.com with all the info, but the site is down for maintenance so I cant link you to it.
In all honesty, there is no 1 good solution to this problem. You need to be prepared for a failure of the computer software system, the compressor, a bag, a height sensor, a air line (splice kits available to patch the line), etc.
I would suggest reading as much as possible on the following forums: www.lrrforums.com, www.landroverworld.org, and disco3.co.uk.
This is a good thread: http://forums.landroverworld.org/showthread.php?t=20014
Ok all that said, I stayed with a 265/65/18 so I can hope to limp out if it all goes wrong. But if you really want an MT, there might be a much better option - GO fit some 17's. You can get good MT's in <32" in 17's. To get 17's to fit you will need front caliper carriers and rotors from a v6 (which are available in the US). Then get someone to send you over some 17" wheels from europe (no 17" were sold in the US) and you're off an running
One last thing, you're not required to stay with the airbag system. Atlantic British just released a conversion kit last month. No real info on the website but it was in their catalog. Around 1k depending on shock option. Although I don't think anyone has installed it yet.
Thanks for all that info!
But what I meant as far as bumpstop was something permanent that would stop the vehicle from ever lowering that far.
Mack73
Yes I know exactly what you mean. You would have to disassemble the air bag/shocks to get inside. Then fab up some sort of rubber bump stop to limit the down travel (probably need a 1/2" increase). I haven't personally taken apart a air bag/shock setup so I don't know exactly what that would require.
But remember this, if you limit the bump stops, you're now limiting the articulation on the trail.....
In my opinon - the best option is to convert to v6 front brakes and run a MT that is 31.5 or less in size instead of fabbing up some custom articulation limiting bump stop extensions.
Howski
just wondering how often the suspension fault issue occurs with LR3's because it seems to be discussed quite frequently when lifting an LR3 is brought up
If your limiting the vumpstops your not changing anything really. If
It hit the bumpstop it would have just hit the tire instead.
I got it, how about a .5"-1" spacer lift? I know people say the 2" spacer lift is no good in the front but .5"-1" should work out better. This will also raise the bumpstop point. Perfect. I might just build my own..
flipstick
