Suspension Bits
timmy!!!!!!!
I have a few suspension bits to sell and both are ready to ship out.
First up is some SG200 springs in decent shape (needs sanding and paint) and will provide your rover with about 2.5 inches of lift in the front. 50 dollars plus shipping.
Second is a pair of 1 inch front spacers (can be used in the rear) for D1, RRC, D2 rears for 35 plus shipping
Or both items for 75 plus shipping.
If you already have a pair of OME medium duty or OME Heavy duty rear springs this should provide a pretty even lift throwing the spacer in the rear. I ran this setup on my disco and could clear 255/85 tires easily.
Also have a pair of front Fox 2.0 shocks that were custom built for Safarigard back in the day that need to be rebuilt for 25 plus shipping. The bottom ends of these need to be replaced and I am not sure if you can get the parts for them. I guess contact Fox about getting replacement ends. They use stock stud to stud mounts. (The bottom of the studs need to be replaced).
AxeAngel
Timmy, can you post up some pics of the spacers and will these fit on a d2 with d1 rear spring perches? (I'm assuming you only have one set of spacers?)
Trying to get to 4.5" on the white d2...
trying to get to 3.5" on the silver d2 (it's tough since RTE stopped making springs) and the OME 3" sits under 3" and the TF sits at 3" for non-laden trucks
Thanks
Sam
