Pajero Mk1 Tourer build-up
Cruisn
Well.. the woman is gone back to Canada for 1 month, so that means I have a bit more time on my hands...
So, metal fab projects all this week.
about 3 hours +paint to go then the roof rack will be good to go:
Cruisn
Custom driveshaft arrived today, thanks to cam for picking that up. appreciate it. although the note was rude.. LOL.
http://i1196.photobucket.com/albums/aa409/cruisn066/Swap/******.jpg
ends changed for proper bolt pattern, along with balancing and straightening. new u-joints to match.
And since I am having clutch issues with it leaking. I bought a new master cylinder, jsut waiting to order a slave cylinder to match.
Cruisn
Got my roof rack home, I like it, Looks good. thanks to dan for transporting it home while the pajero is out of action.
It a tight fit... Can only back in, If I put on 33's and 1" body lift I highly doubt I will even be able to fit..
Cruisn
well, its sunday here in Oz and I have been getting a bit of work done to the pajero. I have a full week off coming up so I am only doing a few hours per weekend. and a bit of custom fab on the weekend. works well for me.
I have installed my new slave cylinder, whihc now holds pressure. so that is another item off the check list. no photo of that, maybe one later.
I also installed the new drive shaft I got, perfect fit, looks great. I am pleased with the quality of the work.
Moving to the outside I ended up test fitting my new headlight covers, to find that it has a set prior and now there are to big of holes to use now.
But they look good:
Moving on I also installed the uhf antenna.
A shot of the front end: looking the part now. I am super happy so far. included is a test fit of my new roo light
Here is a side shot of the lights, there a little big and protrude a bit. but not to bad:
Now onto the big purchase!!
58L aux fuel tank, with electric transfer, this one is a huge increase in quality over the main tank replacement. no spatter, great welds, good paint. I am pleased.
transfer switch and gauge:
All fittings included:
The tank itself:
With this tank I am now able to carry 190L under the pajero with 40L in jerry cans on the roof rack for emergency.
Cruisn
Thanks, I guess I need to do a large update since I have a lot more added, but since I was heading out bush, I slacked on the updates.
here is a photo of it all prepped for my trip.
Cruisn
Has been a while since I updated this thread.
I have almost finished the engine bay, I need a few sensors hooked up still, and to finish mounting the intercooler. but it is coming along nicely and looking quite nice
Dual battery all wired up:
Had to have a custom power steering line made up:
I bought a fridge slid, nice to be able to open my fridge up all the way.
Uhf mounted:
Compressor tucked away here for now to see how I like it:
And had a weekend out. lots of fun.. except all the cleaning that followed:
Cruisn
Well, the weekend is coming.. well not really, but its a great excuse to work on the pajero. tonight goal was a rough mock up of how the led strip lights will sit under the awning and to test light output, I am rather impressed with them. I will soder the wires and heat shrink it all so it never shorts out over corrugations.
In place:
Powered up:
A magazine on the ground, taken with no flash, buthand held so deal with the fuzziness.
And of course a few goodies from milner:
new primer pump as mine was leaking:
The mystery bag. pedal covers, output seals, pressure sensor, washers, the works.
And the biushes I need, this will complete my kit of all bushes except the upper a arms.
Cruisn
THe output is great on them.
Bit more work done, I installed soem new 4" speakers in the front, since the old ones sucked ***. these are a lot better, no photos though.
Then I installed some new pedal covers, much better then the chrome racing covers I had,
new:
Some new parts came in, my 5 way manifold for my breathers, no more water in this guys transmission.. LOL
Camp setup, got a new stove, along with a lantern. our campsite is almsot complete.
Running the lights while cooking:
Cruisn
Thank you, lots to do still. I have a shop stall lined up so I can put the wagon up on jack stands and get all the running gear freshened up, along with getting the wagon prepped for inspection for the engine swap.
oskarf150
