NICE Land Cruiser for sale in NZ
JeepinBear
No relation, just thought it was a slick set up.
Toyota 80series fuel injected 5.7L Chev V8, 5 speed manual, 650Nm torque.
Receipts for over $80,000 on this vehicle
93+ model L/cruiser has upsized braking with larger dia disks & longer splines on the front CVs = stronger CVs
350 c/inch injected V8
5 speed manual
ARB rear diff lock
Centre diff lock
2" suspension lift
ROH 16x8" 4x4 Mags -12 off-set (x 5)
35" Silverstone MT117
Free wheel locking hubs
ARB spare wheel carrier
Custom rubber flares & heavy duty mud flaps
Custom front winch bar = exceptional approach angle
Custom front seats, wrap around with inflating lumbar support (cost $3800)
Custom twin stainless steel snorkels (extra 15kw)
XD 9000 winch
Heavy duty 3500kg tow bar
Front & Rear rated recovery points
Poly Air bags (centre coil spring mounted) for suspension levelling when towing
Dual 12v battery system for high voltage demand when winching
Twin electric fans with manual override (Auto/On/Off) for river crossings / heavy towing etc
Uniden GPS 105 (prs radio) UHF radio with GPS tracking, transmission, speedo, odometer
CD player
Roof cage on galv roof racks
Rear 12v work lamp
Onboard compressor for convenient tyre inflation
Cargo barrier
Tinted windows
Glass breaker / seat belt cutter
2kg extinguisher
Heavy duty 4x4 accessory draw system for convenient and safe storage of recovery gear
Air Conditioning fully overhauled, reconditioned AC pump and re-gas ($1200)
All new brake pads
New brake shoes for park brake
All new shocks including steering dampener
Reconditioned alternator
All new iridium spark plugs
Powered by 5.7Litre Chev fuel injected LT1, ex 94 Camaro on standard Toyota running gear
Dual fuel, Petrol (EFI) and LPG (direct injection) with dual regulators; OMVL injectors, harness & ECU
Bares the usual scars of a well used 4x4 but still very well presented. Fair all round condition and the interior very tidy
Items not included: siren, red emergency lights, O2, VHF
http://www.trademe.co.nz/motors/used-cars/toyota/landcruiser/auction-410777644.htm
RMP&O
FYI....
Only Aussies and Kiwis can buy on TradeMe. About 5yrs ago they put a ban on all other countries. Before that you used to be able to buy on there and then ship it over here.
If you have a friend in NZ (or OZ) it is a very good source for some very good stuff. I bought a 1977 Nissan Patrol Ute on there and shipped it to the USA, pre-yankie ban. I have also bought a bunch of factory made Nissan PTO winches on there. New Zealand got tons of JDM trucks.
Oh and the Cruiser can't be imported to the USA until it is 25yrs old.
Mauka2Makai
Wow dual snorkels :snorkel: :snorkel:. Never seen that before. I wonder what the benefits are? Double the air intake? Double the pleasure? Very nice cruiser though.
RMP&O
It is not so uncommon on v8 trucks across the pond. The big motor, more air, hence the two snorkels. You will see it on a worked diesel from time to time too. It is not really needed though if you calculate things right and size the snorkel accordingly. Example; I was going to run duel snrokels on my built diesel but the builder says by his calculations it is not needed. A 4" snorkel will do the job.
dhuss
