bondvagabond
Well, through a twist of fate, I was able to pull the trigger on a first gen cummins about a year earlier than planned.
I put my International scout project on craigslist for an unrealistic price and it was accepted :Wow1:
Then found a screaming deal on a 1990 w250 with a 1991.5 cummins swapped in. Poor guy needed to fix up the family rig with more seating, with the 3rd kid on the way, regular cab wasn't gettin-r-done. Getrag 5speed, 3.73 gears, 315/75/16 tires, 20% tread left, fancy aluminum wheels, factory rear limited slip, all a/c components are there, but dosen't get real cold he said (was very cold outside when I checked it.) Skyjacker leveling kit in front, silly stainless nerf bars that the wife loves for climbing aboard. Cd player, power windows, power locks (not working atm) 3inch exhaust, very slight timing advance, converted from computer controlled alternator to external voltage regulator (common repair)
Work I've done so far:
New air filter
Oil change
Free fiberglass canopy(was pretending it was a chicken coop on my parents farm since last I had a fullsize rig.....)
cleaned battery cable connections
Work to do:
Battery is dud, torn between great big single or smaller duals, cheap out with autozone crappy battery, or get a good diehard platinum.
rear tire has slow leak, need to fix then save up for new meat.
Get rigging to use my hilift as a winch, including snatch block, since hilifts are only rated at 7k
Some sort of winch, would love a pto. With my all mechanical diesel I could have a winch even without a working battery, I could park on a hill and be all set, even if the electrical system went crazy. I've found a good deal on a 10k pto winch setup, but it is from a chevy 1 ton np205, comes with the whole transfer case, so maybe between the two I could make one work? don't know if the internals are the same? Need info on how to check.
If I can't swing a pto, I will probably do a worm drive electric. Most of them I've seen used are 8k, but they hold 200ft of cable, so even with a snatch block I could still do almost a 100ft pull with 16k load. I don't rock crawl, mostly need a winch to get through the mud here in the northwest, since I am solo 90% of the time.
Put ramcharger tank in underbed spare tire location. The missus and I like to drive out to the middle of nowhere in eastern oregon. Would also allow me to do a veggie oil system down the road to save money
Some sort of locker up front
Junkyard onboard air
Junkyard onboard welder
Weld up some sort of swing out tire/jerry can holder
install 24gallon freshwater tank that I got at a garage sale for 1$
Some sort of sleep in bed system, but like metcalf with his do it all dodge (i'm not worthy
I need to be able to use truck like a truck. So must be collapseable. Have a mil-surp tent wood stove, would be awesome to figure out a way to have it in the bed for snowcamping/winter expeditions to work on the cabin. I'm thinking one of those little crank up vents like on rvs, with a home made metal cap that would replace the plastic/fiberglass one when I used the woodstove.
Let me know what you think, especially about np205 pto winch compatibility.
New air filter
Oil change
Work to do:
