Looking 4 nylon split loom & weatherproof mating connectors used in BajaRack harness
brasskey
I'm looking for the male and female 4 wire connectors used in the BajaRack harnesses. Does anyone know where I can find these? Below is a picture of the male end.
4xdog
There are good deals on Weatherpack style connectors and crimping tools to be found on Amazon.com as well. The trick to installing them is the crimping tool -- with a good tool it's unbelievably easy to do a professional job. Without that tool... well... not so much...
Your local mechanic probably has a tool and may make a few crimps for you if you're only going to use a few connectors and don't want to buy one. I don't know how I'd install them without it.
Don
oskarf150
