Military M101A2 (slow) Expedition Trailer conversion.
Arctic Cat
Hi Guy I'm fairly new on these forum and I have been watching everyones Expedition trailer. While I'm new at the forum, I'm not new at the long term camping thing. Because I'm a disabled vet and getting a little older. I want to travel with some more comfort. I'm also very limited on my income so, I could never afford a Expedition trailer (such as the Chaser and the Horizon), so I decided to built my own.
I already began my project and is going slow but making progress. At first i was not going to share, my project. But I see all you, sharing so I say what the heck.
Well let's see Last September I won an auction , got this trailer for dirt cheap. The trailer is fairly new "refurbishement" that never left the Depot, so the tire were brand new and everything else was ok.
Here are some pictures of the trailer that were taken at the Red River Depot:
https://www.facebook.com/media/set/...1949407660106.96835.1390030955&type=3&theater
Here are my goals:
PROJECT: Expeditionary Self Contained Trailer (ESCT)
Goal: To create a ESCT that will be able to be tow by Jeep Wrangler TJ over trails rated up to 3.5, The ESCT must able to transport supplies and equipment to sustain 2 person on a for at least 7 days without further replenishment through a deserted or forested environment.
ESCT Design Criteria’s:
• Strength to match the Jeep Wrangler TJ or equivalent vehicle.
• Must be simple in both operation and design.
• Must be legal to use on US and Canadian Highways to speed of least 60 MPH
• Rims must remain the same 16X6.5 (235 85 R 16) with a spare inside the trailer
• Actual food preparation and storage area must be bear or other wild Animal proof.
• Must be able to accommodate at least a 2 person Roof Top Tent.
• Must be able to provide a 12V connection with solar charging system.
• Must have a food refrigeration unit.
• Must be able to transport at 5 lbs of LPG on board.
• Must be able to transport at least 20 gallons of water.
• Must have on board provision for showering
• Must have on board food preparation capabilities
• Must have braking system.
• Must have a Pintle Hitch or equivalent.
• Must be military desert flat color.
• Must be under 2,000 lbs
:coffee:
Woods
What's the weight as it sits? I'm thinking 2K lbs. might be tight???
Looking forward to seeing what you come up with.
Arctic Cat
The trailer dry weight is 1,340 lbs, I'm planning on 2,000 LBS total. I'm not much of a packer and I usually take the bare minimum. We built around seven of them when I was in the service. We used our for foward observer. I usually spend about 3 to 4 week on the road myself. I'm planning on keeping everything in or around the 2,000 lbs mark.
Arctic Cat
Tailgate: I needed the tailgate to lay flat so it double as a table. Problem: Chain was too short. Solution: Went to Harbor Freight and purchased 2 feet of chain, 2 chain link connectors and 2 hooks. cut the chain into 2 five links sections hook the chain links and the 5 links section to the end of the original chain and the 2 hooks to the end and presto the tail gate now open as flat table. Cost: less than $5.00 Here is the picture:
set
Dirtytires
Good choice there. Alot of people are using wire or cable to cut down on the noise and weight issue. Keep up the work..
Arctic Cat
Military or Civilian look?:
Early on in the project I asked myself the question, do I want the trailer to keep the military look or do I want to convert it to a civilian looking trailer? Keep on mind that I'm a veteran and I’m a firm believer of keeping things as original as I can, while still serving my purpose. With that said I was willing to put my preference to the side and look at it from an outsider perspective. I also enlisted the help of several individuals, including a utility trailer manufacturer, several Jeep Expedition individuals, and three ex military guys to help me make a better opinion. Before I get to my decision here is a little history on the trailer. The trailer was pick- up at the Red River Army Depot, Texas, while picking the trailer I found all the maintenance paperwork regarding this trailer. The trailer is 1990 Kasel M101A2. The trailer like many other trailers in the military arrived to the depot from Fort Hood Texas for an overhaul. The trailer arrived on June 2007. The trailer was completely overhauled and that was completed on 11/04/2008. By that time the trailer was deemed obsolete as all the M101A2 were being retrofitted to be M101A3. So the trailer was parked and remained there waiting to be retrofitted. The trailer was never retrofitted, as the M101A3 also became obsolete and is being phased out for a newer trailer. So the trailer remained there parked until September, 2011. I won my bid ($441 out the door) for the trailer on 09/14/2011 and pick up the trailer on 09/29/2011 and pull it with my Jeep for a little over 300 miles. (I did not need an ECU) So I weight the issues as follows:
Military or Civilian Conversion? - To make that decision I sat down and talk to my “team” to tackle several issues:
Registration: Under Texas Law an ex military vehicle of any kind pay a flat fee of $50.00 for a 5 years registration, as long as the vehicle remain pretty much military looking in nature. In comparison a civilian trailer of equal weight, pay $60.90 per year. Additionally as an ex military vehicle I don’t need a license plate for the vehicle as long as there is a military unit number in the rear of the trailer. So cost effectiveness on this specific issue dictated a military conversion.
Tires and Rims: Originally I wanted to change the tires and rims to be same size as the Jeep (31 10.50R15) to match the spare. The original trailer tires are 235 85R16. We agreed that the rims did not need to match the colors of the trailer, as this would bring the cost up and we were already leaning toward a military conversion. Additionally it was agreed that I should have 2 spares anyway, just in case. So the decision now was a matter of size. We measured both tires from top to bottom and the difference was only ¾ of an inch (that would have lower the trailer only .375 of an inch). The tires on the trailer are brand new (Still got the little knobs). A spare tire cost $154.00 and the matching rim to the trailer was $35.00. Aesthetically having matching rims and tires with the Jeep would have been nice, but practicability and economically the original tires were sounding a lot better so a decision was made to keep the original tires.
Paint: Well to be honest the military is not known for their paint jobs, plus additionally they use CARC Paint (Chemical Agent Resistant Coating) and CARC paint peel off very easily if the job is not done right. There are some areas on the trailer that the CARC Paint is peeling off. The trailer has no rust whatsoever. Taking the trailer to get sandblasted and painted the same color as the Jeep (Yellow), would has been aesthetically nice. But it was taken into consideration repairing and scratching the trailer while in the field. Painting the trailer would have mean that I would have to take the trailer to the shop to be repainted. On the other side of the coin, the actual paint color code number for the desert tan trailer is 33446. The paint can be match at any hardware store (such as Lowes or Home Depot) and is readily available on spray cans at Rapco Parts (http://www.rapcoparts.com/336tancsucud.html), meaning that repair can be easily done in a cost effective manner. Additionally the cost of sand blasting the trailer to match the Jeep was prohibitive and not very practical. So again my “team” and I leaned towards a military motive. So overall a decision was made taking all issues in consideration to keep the trailer military looking. Sorry for the long post
Arctic Cat
Axle, Suspension and Trailer Height:
AXLE & SUSPENSION: Originally I was planning on replacing the axle and the leaf for a lighter one with electric brakes. The idea was to make the trailer lighter and of course lower it a bit. I went to a trailer manufacturer and I took the trailer there and show him what I wanted to do. Running the trailer without any brakes was not an option as the Jeep is a smaller vehicle and the surge brakes work so well on the trip back from the depot that I knew there and then, that some sort brakes were needed. I was explained that switching the axle for a 3500 axle with electric brakes would not make a major dent as far as weight goes. Additionally it don’t matter how light the trailer is, I still would need to change the gears on my differentials as the TJs are not known for towing. I also love the fact that the trailer has parking brakes, eliminating the need for chock blocks. Once again I talked this with my “Team” and it was again decided that the cost would not justify the benefits. But the issued was still there, the trailer have to be lower just a bit for two reasons:
Travel Height: When I originally got the trailer the rear was very high, as the Pintle Hitch on the Jeep was about 15 ½ inches of the ground. See picture:
Solution: Purchased a 5 TON Pintle Hitch, and a 6 position receiver and a couple of hooks for the safety chains and presto (In addition the Jeep is to receive a 2 inch lift sometime next year). This is what the hitch look like:
Stationary Height: Now the problem was the height when the trailer was parked. As you can see in the drawing below, the height of the trailer was a little bit high in the rear when the trailer was parked. I wanted the trailer to be level as I do not plan to sleep on a slanted position.
So to see if the trailer would go down with weight, we literally overloaded the trailer with 40 cinder blocks to 1,040 lbs (something that I would never tow as I’m planning to stay within the 2,000 lbs limits.) The trailer was still high.
Solution: Removed 2 leafs from each side and the trailer came in within normal height, we tested it at first with 520, lbs, and then with 1,040 lbs and it was perfect, about as level as it going to get.
Cost: Pintle Hitch-$50.00, 6 Position Connection-$80.00 and the 2 Hooks $1.00 a piece
Arctic Cat
ELECTRICAL TRAILER TO HITCH CONNECTION:
My Jeep is equipped with flat 4 PIN Connection. The trailer is equipped with NATO 12 PIN Connector. In addition the Jeep is 12 volts, while trailer was equipped to be used with 24 volts towing unit. Since the decision was previously made to maintain the vehicle as military as possible I needed to used the military light fixture already on the trailer (by the way they are bomb proof).
Jeep Soluction: I converted the 4 PIN Flat conection with a 7 Blade Connector. Like this one, http://www.etrailer.com/Wiring/Hopkins/37185.html, now I needed a 7 Blade to 12 Pin NATO Connection like this one, http://eriksmilitarysurplus.com/mitradcamtro.html and NATO Trailer receptacle cover, http://eriksmilitarysurplus.com/trrecommve77.html and standard bracket to place the NATO Conection. Now my Jeep accept 4 PIN FLAT, 7 Blades and NATO PIN Connection.
Cost: 4 PIN Flat conection with a 7 Blade Connector-$25.00, 7 Blade to 12 Pin NATO Connection $72.00, NATO Trailer receptacle cover-$16.00, Standard Bracket-$3.50
It look like this: https://www.facebook.com/media/set/...1949407660106.96835.1390030955&type=3&theater.
Trailer Solution: Very easy, switch the two top 24 Volt light bulbs for 12 Volts light bulbs (Top one is #91 and the second from the top is 1156.
Cost: About $5.00
PS: if you have problems check your ground first also here are the numbers for the light connections
> 21, running/parking lights
> 22-460, right turn signal
> 22-461, left turn signal
Scrapdaddy
Good job so far. What type of front landing gear do you have. Some A2's have the newer crank up type. Trying to lift your trailer off the hitch, when loaded, is too hard. We need some pictures!
Arctic Cat
I wish it have a crank up, but it have one of those drop down gear. Now what I do to unhitch the trailer :
1) I set the parking brake on the Jeep.
2) I set the parking brake on the trailer.
3) Release the parking brake on the Jeep.
4) Drop the front landing gear.
5) Released the parking brake on the trailer.
6) Push the trailer back with the Jeep and automatically the landing level go on a straight position and the lunette un-hook from the pintle.
To hitch the trailer
1) I place the trailer and the Jeep in the desire position.
2) Released the trailer parking brakes (The Jeep parking brakes stay on)
3) Pull the trailer until the lunette fall on the hitch. And the drop down gear is loose enough. Raise it and lock it.
Scrapdaddy
Man, that could be a problem, if in the wrong place and you needed to drop it. That's why I wound up buying a few A2's and A3's. The A2's had the new landing gear, but didn't have the enlarged bed, between the wheel wells. So, finally I got a A3 with everything I need, four trailers later
seth.c96
