❇️ How To Super INSULATE 12v Chest Fridge / Freezer?
magentawave
I have been using a 12 volt ICECO VL60 chest fridge/freezer 24/7 for the last three years and it has worked perfectly. I’m thinking about buying the larger ICECO VL90 chest fridge/freezer for my box truck to camper conversion build.
Since I’ll have a lot more room in the box truck I would like to SUPER INSULATE the outside of the VL90 in a way that I will still be able to pull it out on slides and easily access the fridge and freezer from the top.
I was thinking of possibly using Velcro to adhere poly iso foam sheets to the bottom, sides and top. (Obviously I will keep the vents open.)
Anyone done this? Got any ideas?
Thanks!😀
Antwon412
Some companies make insulated covers. Perhaps there is one available for your fridge. I have a set power fridge and purchased a set power insulated cover for it and I’ve been very happy.
Peter_n_Margaret
You want a super insulated chest fridge?
Build your own.
12V compressors/evaporators/condensers and a thermostat can be purchased. The rest is an insulated box that you can easily build any size, any shape, with the best insulation at any thickness.
The compressor/condenser should be remote form the rest of the unit so as not to spoil the insulation.
Insulation is closed cell polyurethane foam 150mm thick.
Cheers,
Peter
OKA196 motorhome
magentawave
Build your own.
View attachment 846200View attachment 846201View attachment 846202View attachment 846203
Cheers,
Peter
OKA196 motorhome
Hmm, I was going to build one in a boat I used to have but never got around to it. That could save me some $ and certainly end up with something much better than anything on the market. I’ll need to make another deep dive into building one so thanks for reminding me!👍
magentawave
ICECO makes covers too. Haven’t seen one in the physical but they look kinda thin. Have you noticed a difference using a cover vs no cover? Less cycling?
TwinStick
Just my 2 cents, yes, you can insulate it, and even get creative. Just don't forget to upgrade the actual exhaust of the heat that motor produces. I always have run an extra fan on our ARB fridges in hot weather. It would run nonstop in 100° heat solo. The extra fan helped a lot.
OldManClements
