01 montero tail light issue
Mozo
Im having trouble with my right side tail lights. The fuse controlling the circuit keeps popping. I disconnected the actual light assemblies but the fuse still blows as soon as i turn the lights on. So..short somewhere...anyone have an idea of where i should start?
Thanks in advance.
dvdswan
Have done any work on the vehicle where you may have shifted the wire harness around? Grinding? Remove/reinstall? Drilling? Etc.
How are the grounds for the light with the issue.
Mozo
I havent done any work involving the harness.
I disconnected the upper and lower right side tail lights. Im under the impression those are the only lights on that circuit.
Mozo
I suppose i am looking for a short in the harness..
Fun..anyone have any insight into a suspect area to check?
The service manual should have connector locations. If it shows any connectors between the fuse and the tail light, you can disconnect the connector. That would help narrow down where to look for the short.
jacob_lashell
