05+ Tacoma question - tire size
calamaridog
My dad needs new tires on his 05. What sizes fit without rubbing on the stock suspension. 4x4 DC. Thanks:)
crawler#976
With stock rims 265/75-16's will make minor contact at full stuff, full lock. It's easily cured with very slight trimming of plastic.
If you have aftermarket rims that don't have exactly the same backspacing/width as stock, it takes a lot of trimming to clear a 265/75-16.
Mark
wagner_joe
I run 265/75/16 on my 05. BFG AT's. I have Moto metal aftermarkets. They rub slightly up front. Lower screw hole on the outer plastic fender flare. Otherwise, I ran fine prior to my lift.
calamaridog
TACODOC said:
265/70R16 is stock.
My 255/85R16's are GTG, only a slight rub when in reverse at full lock.
.02
Doc,
I'm pretty sure his are 245's? right now. My 01 had 265/70r16's though... Anyone else come with 245's they can remember?
Anyways, thanks for all the responses so far.
Dave Bennett
Adventurist
calamaridog said:
Doc,
I dont know that I've ever SEEN one with 245's on it...
Mine came stock with 265/70R16's though.
taco chaser
Supporting Sponsor
Hey Joe, how's the Taco Donkey coming along.
Jacket
2008 Expedition Trophy Champion
245's are stock on the non-TRD models.
As others have stated, 265/75 seems to be the consensus for stock height, stock suspension 05+ Tacomas. And this size should also fit underneath the bed without any issues.
7wt
If you want the tall and skinny thing do a 235/85. They will fit without any problems and they are a 10 ply super stout tire.
iStan814
