06 Pathfinder
RakkasanFA
Are there any other lift kits out there for the Pathy besides the PRG one? I don't want to go any higher than 2 inches.
Thanks.
Welcome to the forum Barry. There's a good bit of information about lifting the 05+ PF's over on this site, as well as some other info specific to the model;
TheNissanPath
I've been toying with the idea of putting on 08V8 PF Nissan OEM front struts/coils and rear coils and shocks on an 07V6 which should give about an inch lift all the way around and stiffen the ride somewhat, but there a few other options to look at yet.
PRG is just a spacer kit right?
There is very little after market support for the 05/06 R51 Pathfinder. However, I believe that Old Man Emu (ARB) has a lift for your truck that I think will do just over 1".
For the front, there is a stock or medium version (medium is better if you have a winch) and the rear there is a stock or a heavy option that is for people who always carry a few hundred pounds. Just a guess here, but I'm thinking around $850 for front & rear (don't quote me on that!).
There are a bunch of ExPo sponsors that sell OME - just give one of them a call for a quote. The list of vendors is at the bottom of the home page.
Pete
Pete
Yes. The PRG is 2" spacers all around. I will look at the other sites to see the OME suspension.
Here's the ARB catalog showing the Old Man Emu suspension for the 05+ PF's;
ARB Pathinder accessories
Like most suspension modifications the alignment has to be reset for the OME upgrade to work right. Without adding a front steel bumper or additional weight such as a trailer in the rear most are seeing about 1.5" lift at the front and about 2 1/2" at the back measured above the tires, with the medium spring front / medium spring rear mod.
ELShockley
