08+ Tundra Buyers Guide
D45
Currently shopping around for a used Tundra 4x4 auto
My main concern is bed size and rear seat room, for the kid and car seat
I found these specs for a 2014
Cargo area dimensions:
-length (inches): 66.7
-front width (inches): 66.4
-width between arches (inches): 50.0
-height (inches): 22.2
-length (inches): 78.7
-length (inches): 97.6
So are there actually 3 bed sizes?
I think I am pretty set on the 5.7 motor
310-hp@5,600 RPM 4.6-liter V-8
327 lb.-ft. @ 3,400RPM
381-hp @5,600 RM, 5.7-liter V-8
401 lb.-ft. @ 3,600RPM
What issues or known areas should I watch out for when shopping?
Regular 87 octane gasoline for both V8 motors?
hol571
I've got an '12 double cab w/ 6.5' bed, so I'll try to answer a few questions. First, tundratalk.net is a great tundra specific forum.
I'd go w/ the 5.7, and 87 octane is fine unless it has the supercharger.
the double cab had 2" more rear seat room than the 4 door tacoma when I was shopping, and comes with a 6.5' or 8' bed
the crewmax has a ton of back seat room but only comes with a 5.5' bed
a car seat fits without a problem in a double cab
the rockwarrior was just different wheels/tires and color matched bumpers compared to the trd offroad package
TSS was something for southern states, so I don't know the differences, but it was mainly cosmetic
avoid front spacer lifts like the plague, if you want any lift in the front go with the bilstein 5100 at a minimum, or upgrade to some nice coilovers (icon, king, fox, ads)
camburg, total chaos, and icon all make good uca's
stock front is ~3" lower than rear
@coachbuilder1 on tundra talk makes some really nice shackles for rear lift
@zidaro has a great build thread of an '10 crewmax here on the portal, I definitely recommend reading through it: http://www.expeditionportal.com/forum/threads/50656-10-Tundra-CrewMax
bigwapitijohnny
Tundra is a great platform...
D45,
I have a 2011 Tundra Crew Max, and I think this is a great platform to build upon. I started with a grade model and built it up myself. I don't have any buyer's remorse on this decision. Toyota reliability, plenty of room and a bomber engine...It has been a great vehicle. I would not hesitate to buy a Tundra again.
Tundra talk is a great resource, you just have to wade through the 'mall-crawler' threads...Good luck.
Regards,
BWJ
mike h
There aren't really any issues to be aware of. Get the 5.7 V8. Decide what makes more sense for you: Bigger bed and smaller back seat or bigger back seat and smaller bed. Drive away happy!
The TRD package is, in my opinion, a light duty off-road package. If your plan is to build it as an off-roader I'd buy a cheaper model (or more expensive interior upgrade) and add suspension and skid plates as needed.
toylandcruiser
Gear options?
Chain tcase?
Chain tcase is kind of irrelevant.
"The right of the people to be secure in their persons, houses, papers, and effects, against unreasonable searches and seizures, shall not be violated, and no Warrants shall issue, but upon probable cause, supported by Oath or affirmation, and particularly describing the place to be searched, and the persons or things to be seized."
toylandcruiser
You're kind of a lazy searcher aren't you?
FiscAnd
