100 stock height
zimm
i've got an aftermarket suspension, and a ton of mods. im going to get some slee upper arms to set the alignment to stock. the instructions call for an arm setting baseline of "d" for a 2-3" lift.
i have no idea what the stock suspension setting is on a 100, so, i dont know what what the front end of mine s under load. oh my.
does anyone have the measurements from the center of the wheel to the fender lip, on a dead stock truck? level ground, wheel straight, yadda yadda yadda...
i may have to keep a tape handy in case a see one on the road. :)
Jahwn
Mine is stock except for new tires which are 285/75/16. Measures 20" from center of hub to fender lip.
zimm
hm. interesting. i thought id be higher. with heavy ironman springs in the rear, and leveled out, im at 21" front, 35's are just a tad rubbing on the frame when compressed.
this could explain why i didnt get the squirrelly highway handling after i leveled out.
i may have to 30mm space the rear, crank the front and UCA. apparently i have an inch left on the table.
dhuss
