109 Custom build up.
overlander
Thanks. i was hoping you found a source for series and defender long range tanks in the US. no worries.
Harald Hansen
Standard issue on the Norwegian Land Rovers were two under-seat tanks.
(I'm Norwegian, reserve military and a Land Rover fan... :) )
DCH109
109 FFR's as well? Someone else mentioned their 109 had the same fuel tank. Mine has the front under the seat and that aluminum one in the rear.
Just wondering and thanks for the info.
It has been hard to find out much about it other than the release papers i have.
DCH109
Thanks Harald
So no new progress this weekend. Mothers day and all. I will be fabing up the engine mounts and setting up the axles this week and weekend so i will have more pics soon.
It feels good to start the buildup.
cumminsrover
Glad to see you've made at least some progress! Too bad there wasn't time to put on the new rear crossmember before you picked it up :(
I have made some as well, but it has been kind of rough getting the shop back together since I moved right after you picked up the chassis, and you also had the same problem....
Patrick
4Rescue
This looks to be a great build. I'm not a fan of the 350, but other than that it sounds great. So is this a Pick-up style body? Looking at the removed rear tub I don't see a pass-through, but a front wall?? Can't wait to see more of this build as it progresses.
Cheers
Dave
Thoma_s
All the way from norway
This will be a nice Land Rover.
How goes it with your project?
How is it that you got a car all the way from Norway?
zhukoveli
