1988 Samurai Tin Top.
Mr Ed, sorry I missed responding your post. The engine swap used the Samurai transmission and transfer case and a adapter plate.
The main reason I did a diff gear swap is the 5.38s 3rd members came with the Samurai when I bought it. At the time I figured a 3800 rpm cruise wouldn't be too bad. I was wrong about that. It would be acceptable for a trailer queen, but not for a adventure traveler.
My thought for doing a diff gear swap again are as follows. The 6.5 TC gear set, which is what I would need, is $600. They would give me a 3051 rpm cruise at 55 mph. The 4.57 diff gears are $378 for both. They would give me a 3110 rpm cruise at 55. The diff gear swap will also correct my speedometer. Granted the TC gears would give me a better low range gearing, but I'm not going to be doing a lot of rock crawling with this rig.
Gotcha. Well it sure is a nice Samurai man! I'm jealous of the lack of rust!
Ed
Nothing new but I have put some miles on it.
I put about 150 miles on it this weekend. Exploring around home has been a lot of fun.
Here's a teaser.
The rest of it is here.
Ill be adding to that thread as the miles add up. I'll be adding to this one as the Samurai evolves.
Cool pics! The only things around here that old are rocks, some of the trees, and the odd pictograph.
I have added several circuits to the electrical system to power the air compressor, inverter, etc. When I wired them I used inline fuses and tied them straight to the battery. Elegant it wasn't, even if it was serviceable. I replaced all the inline fuses yesterday evening with this.
This, being a auxiliary fuse panel for a boat. It's mounted under the hood right beside the battery. Since it's a marine fuse panel, all the hardware is stainless.
One more little thing crossed off the list. :sombrero:
Had a friend who had a Sammy back in high school. Loved that rig. I'd love to have one as clean and nice looking as yours.
Another update.
I've been hauling a canoe on the roof racks some, but if the family wants to go I need to haul two canoes, life jackets, cooler, and 4 people. That means hauling a trailer and that means I need a hitch. Unfortunately, I cut off the original hitch because it interfered with the rear shackle mounts. Time to dig out the welder. :ylsmoke:
I wanted a bolt on hitch that would be durable enough to be my rear tow point as well as accept a receiver mounted winch. This is what I built.
It started out life as a hitch for a Chevy Venture. It was 1/2 inch too wide for the Samurai frame. A little cutting and welding solved that problem.
It mounts up under the bumper nicely and is held on by 4 grade 8 1/2" bolts. It should be plenty strong enough for anything I use it for.
The trailer I will be towing is this one. It was acquired from a friend for free. Originally it hauled kayaks. I will be converting it to a camping/canoe hauler. It will be going under the knife soon. I will probably do a separate build thread for it.
More to come as it happens.
very nice. i spy a kitty kat.
the plate the hitch ball bolts to, i would weld a gusset from it to the square tubing that slides into the receiver dealy. can tell its slightly tilted down
That's my generator moving hitch. It was the only trailer I had with a 1 7/8 coupler. The camping trailer will probably end up with something like this.
Wolfbox
