1995 Mercedes 410d 4x4 - Rare, unique and expedition ready! $99000 o.b.o.
Rare opportunity to own a true expedition-ready vehicle built on legendary Mercedes reliability. This rugged overland camper is powered by the OM602 5-cylinder diesel — widely regarded as one of the most durable engines Mercedes ever made. No electronics, no ECU, no nonsense. Just pure mechanical simplicity that you can fix with basic tools anywhere on the planet.
Equipped with selectable 4x4, high ground clearance, and a fully outfitted interior designed for long-term, off-grid travel. Everything you need — nothing you don’t. Built for overlanders who value extra space, function, field-repairability, and self-reliance.
Specs & Highlights:
• Engine: OM602 5-cylinder diesel (non-turbo) – bulletproof, easy to service
• Drivetrain: Selectable 4x4 with low gearing 2.5:1 and a 5 speed manual transmission
• Camper: Fully self-contained with essential systems for extended travel
• Electrical: Minimalist setup – no ECU, no complex electronics
• Repairs: Globally serviceable; maintainable with hand tools
• Condition: Mechanically and visually sound, ready for remote travel
• Price: €90.0000
This is the kind of rig that gets you out there and back.
If you're looking for a reliable, go-anywhere, no-frills overlander with real soul — this is it.
Price is negotiable.
Willing to help with international shipping.
Details:
1995 Mercedes 410d 4x4 (Larag)
Om602 motor
39000 km
The van had 5000km at purchase
Originally stationed with fire department in Teufen, Zwitserland
4x4 conversion by Larag with 2H, 4H en 4L with 2.5:1 gearing
A true off road set up.
Registered at 3500kg but allowed 4600kg
B class License
6m / 236in long
2.85m / 112.2in high
3.7m / 145in wheelbase
Interior:
Professionally built by Camperbouw
Limburg in 2019
XPEL Prime XR Plus ceramic window foil windshield and side windows with 99% UV block. Makes having the hot sun shining considerably more tolerable in the cab!
Heated mirrors...no joke.
Sound insulated and rattle free front doors and dashboard
Outbound double glazed window with midge net and sun screen
Gebo flush line roof hatch + midge net
Armaflex 19mm insulation
Silent Coat 2mm sound deadening layer
Floor insulation 2 cm + cork layer
40L water tank
2x water pump for extra pressure
Extra long faucet hose that doubles as shower
Indoor shower tub. Takes very little space and works as a storage drawer.
Secret compartment for valuables
Hot water boiler 10l
Planar diesel heater
2x Caframo Sirocco 360* ventilators
HEKO window spoilers on front doors.
LED interior lighting with 6 colors in 4 zones
Magnetic window sunshades by Busgordijn.nl
Fixed bed 200x160 / 78.8in x 63in
Roof fan Ventline Vanair 2x
Security:
Bearlock gearbox lock
Bull Lock back door lock
Pedal lock
Electronics
Victron Phoenix 12V - 230V 1200W + remote
Solar panel Panasonic HIT Mono 295W
Cellpower CPC 250Ah AGM battery
Victron Smart solar mppt 100/50
Victron Bluesmart IP22 battery charger
Victron battery monitor BMV 712 smart
Refrigerator Vitrifrigo Sea Classic C115L
Reverse camera with parking + driving mode with 7 inch AHD screen from Spy-tech
Garmin Dash Cam 55
Lighting:
Angry Moose 40 inch lightbar
Angry Moose H4 6000k LED headlamps
2x side shooter lamps
1x work light rear
Extra extra:
Custom reinforced driveshafts: transmission-transfercase-front axle. These drastically reduce vibration and are considerably stronger then the standard ones.
Mike Sanders Fett anti-corrosion treatment on entire frame.
Fully walkable custom roof rack
5x rims GABO 16x8 et75 Custom order. They don't make them any tougher. For Germans: some people managed to get TüV approval. See forums.
5x Tires BF Goodrich K02 All Terrein 265/75-16 99% profile
The better (best?) All Terrain tires with 3pms snowflake so legal in Germany for winter.
Awning 3mx3m 118inx118in built for the fire department with extremly stable aluminium construction.
Rotating ASS ergonomic front seats
Shock absorbers front and rear custom and calibrated from Marquart GMBH
Air compressor Horn 2 cilinder 300l/min 10bar
Instagram @Feersum_adventures
2eleven
