I have a 96 Toyota Land Cruiser. It has 220K miles. Well maintained and well built for overland travel or daily driving. This is the third 80 series I have owned and by far the best. Only selling because I want to buy a van. Located in Crested Butte, CO. Some of the pictures are with the Dobinson springs. The truck is currently setup with the Slee 4" springs but the Dobinsons are included. They would be perfect if you want to run a roof top tent and add the second battery. They were a bit stiff for the current weight of the truck.
Highlights:
- limited edition leather seats with new seat bottom cushions in the front seats
- 4.88 ring and pinion gears installed by Cruiser Specialists in Austin, TX
- ARB air lockers front and rear installed at same time as the gears and they use the stock switch (some say the ARB lockers are more reliable than the stock e-locker)
- full Slee 4" lift kit including slee springs, dobinson shocks, slee front radius arms, rear adjustable upper control arms, front DC drive shaft, extended bump stops, adjustable panhard rods
- full length Front Runner roof rack
- ARB drawer system in rear
- snorkel
- upgraded Depot headlights with led bulbs
- front ARB bumper
- rear 4x4 labs bumper with spare tire and jerry can holders
- Scan Gage 2 installed
- Slee sliders
- hard wired for fridge (could include the SnoMaster fridge for the right price)
- Speski cargo barrier
- AluCab 270 awning
Preventative maintenance:
- Head gasket replaced and head rebuilt by previous owner at around 150k miles.
- Oil, transmission fluid, transfer case fluid and differential fluid were changed regularly by a professional shop for at least the last ten years by previous owner.
-Front seats were recovered around 2014 by a previous owner.
- Jegs catch can added to pcv line.
- Extended front and rear axle breather lines using kit from ARB.
- New battery.
- Replaced rear driveshaft with new OEM unit with new joints.
- New Toyota oem alternator.
I also have some extra parts:
- oil filters, spark plugs and some other misc. stuff
- 4" super heavy duty dobinson springs (if you put a RTT and add more weight)
- Land Cruiser Phill auxillary fan
- Slee second battery tray
I'm sure there is more, but this is all I can think of right now. This truck runs and drives great. Price is $21,500 if you are interested let me know and I can get you a bunch of pictures
Highlights:
- snorkel
- front ARB bumper
- Slee sliders
- AluCab 270 awning
- New battery.
