2001 tacoma small problem
tbar
when i start up my 2001 tacoma 5spd
there's a loud whinning noise for about 2 or three seconds then it goes away . doesn't happen all the time
not sure if its the belts or bearings
anyone else experience this problem
thanks
dnellans
sounds an aweful lot like a belt... go get a carwash and powerwas the engine bay, if it whines longer than after a normal start then belt is likely the problem
-d
xcmountain80
Sounds like a belt, I think my 4Runner does that now for about 15 seconds or so, almost like the belt has to warm up or something.
Now if it's a loud screeching then likely a belt again, they aren't hard to replace and yes do all 3 at the same time they are a bit of a pain in the rear to doubt doable for a home mechanic.
Aaron
SOAZ
Tim and Kelsey get lost..
Sounds very much like a loose belt. A little extra tension should take care of that. (Post a video if you can to make sure that's it)
4xCoffee
