2002 Acela Monterra Overland Platform (Sold)
jlandreneau
2002 Acela Monterra 4x4 (up-fit completed October 2018)
7,231 miles at Acela up-fit
Current mileage: 47,xxx miles
Price: $xxxxxx
Located in Lander, Wyoming
We are selling our beloved LMTV to downsize for the next chapter of our lives. We have lovingly built, maintained, and lived in the truck over the last 3 years. She will make an excellent starting point for a new rig. As she sits, a flatbed camper designed for an 8-foot bed could be installed, or the flatbed could be removed and she will accommodate a 15’ habitation box. We are happy to consult on this process.
The truck is mechanically sound with a recently rebuilt engine, low miles, and a four-year extended warranty with towing coverage from CAT. She is not your typical LMTV with 20+ year old components. The truck was up-fitted into an Acela Monterra in 2018 via their rigorous Certified Reset Program including a 300-point inspection and 600+ new parts. In addition, we have continued to inspect and improve her over the last 3 years. The bulk of the work was completed in summer of 2019, unless noted otherwise. See the list of upgrades and custom fabrications below. All work has been performed in a high-quality manner with careful attention to detail to ensure the original specifications of the truck are maintained. This includes approach/departure angles, ground clearance, weight distribution, and overall dimensions.
The subframe was designed so that a flatbed, as currently configured, or a habitation box can be interchanged as needed. However, almost anything could be built on the subframe to accommodate a variety of needs. The storage boxes, tire carrier, and rear fender wells are all connected to the subframe so changing out the function of the cargo area is as simple as releasing the four corner connections and disconnecting the wiring harnesses. The design intent is that this 2.5-ton truck can meet almost any need. Message us for additional information or pictures.
404-834-5727
SPECIFICATIONS & UPGRADES
Engine: Caterpillar 3126 7.2L inline 6-cylinder, turbo charged, electronically controlled fuel injection
Transmission: Allison MD3070PT 7-speed automatic transmission, electronically controlled with push button shift selector
All wheel drive: 30/70 spilt with 50/50 engaged via mode function
Tires: Goodyear MVT 395/85/R20, New only 600 miles on the tires
Wheels: Hutchison aluminum, no beadlocks
Central Tire Inflation System (CTIS): Functional and works well
ENGINE
Up rated to 330 HP (Acela)
CAT out of frame Platinum engine overhaul performed by Yancey Power Systems (November 2020)
New water pump (August 2020)
CAT OPT 48-month transferable warranty on engine rebuild, includes towing
New oil pan (January 2021)
New PacBrake solenoid (February 2021)
New lower coolant hoses (January 2021)
New power steering pump hoses (October 2021)
AirDog fuel air separator system with IMCO SuperFuel valve for dual tanks
Delam Solutions injector filter kit
New filter and o-rings (October 2021)​
Exhaust gas temperature probe with Auber digital display, probe installed post turbo
Custom exhaust routing with 7” black exhaust tip
Exhaust is heat-wrapped from turbo to muffler
DRIVETRAIN
Automatic rear axle locker (Acela)
High speed gears for a final gear ratio of 6.14:1 (Acela)
Resealed & inspected transfer case (August 2020)
Resealed & inspected transmission (November 2020)
CHASSIS
GVWR increased to 23,600 lbs (Acela)
GCWR increased to 35,600 lbs (Acela)
Relocated stock equipment behind cab
Custom cab air leveling & ABS computer mount​
PowerPacker selectable cab lift handpump (May 2021)​
Custom dual Donaldson PowerCore PSD air filter system with aluminum intake tubing​
Removed anti-polarity protection device​
Removed stock air filter, air over hydraulic, & tire carrier systems​
Baked on black frame coating (Acela)
Custom front fender guards with cab bump stops
Haldex PURest air dryer (Acela)
Relocated air dryer, air tanks, and battery box forward on chassis
Automotive air quick connect fitting on wet tank
175-gallon fuel capacity via two custom aluminum fuel tanks
95 gallons on the passenger side​
80 gallons on the driver side​
Custom tank support brackets with option for skid plates​
1,100 mile + driving range​
IMCO SuperFuel switch controls sending units & supply/return flows​
45-gallon marine grade 3/16” thick aluminum gray water tank between chassis rails
Installed on spring isolation mounts​
Custom steel subframe
Heavy-duty spring mounted subframe with ISO “shipping container” corner mounts for interoperability of truck cargo area​
Designed for 7’-6”x15’-0” habitation box or similar​
Cab color-matched powder coated springs and black powder coated subframe​
Custom swing down powder coated rear tire carrier with license plate mount & light​
Custom Alum-Line aluminum storage boxes mounted to subframe​
Custom ¼” thick aluminum rear fender wells​
GloLight LED rear stop/turn/tail lights mounted in subframe
Baja Designs Squadron Sport flush mount reverse flood lights mounted in subframe
Custom Alum-Line aluminum flatbed
Designed to fit subframe​
Includes headache rack, “garage” storage box, and 2x6 wood decking​
LED marker lights​
“Garage” storage box is insulated with 1” rigid foam with 1/2” plywood floor​
LUX Lighting Max LED lights in “garage” storage box controlled via sPOD​
L-track storage solution in “garage”​
Custom front winch bumper with Sherpa Stallion 25,000 lbs winch & synthetic winch line
Stock front tow points are maintained​
Custom rear winch mount with Sherpa Stallion 25,000 lbs winch & synthetic winch line
1” thick steel rear tow points included​
Fox LMTV tuned shocks (March 2021, Grigsby Truck)
Cab airbag suspension system (Midwest Military Equipment)
Eco Flaps aerodynamic front and rear mud flaps
LUX Lighting Max LED magnetic rock lights fore and aft of each wheel controlled via sPOD
LUX Lighting Max LED magnetic engine lights controlled via sPOD
SYSTEMS & CAB
Ametek NGI digital dash system (Acela)
ScanGaugeD
Auxiliary fuse block (Acela)
Reddot AC/Heating unit with windshield & floor vents (Acela)
Cruise control
Headliner and interior panels (Acela)
Fabric covered door panels; jute padding added to interior panels, & rigid foam insulated rear cab wall
Custom aluminum pass through frame with cover plate and insulation
sPOD Bantam touchscreen auxiliary power system, touch screen mounted on dash
VisionX 5.75” & 7” VX series black chrome headlights with white halos & dual beam high beams
Baja Designs Squadron Pro wide cornering ditch lights mounted to roof rack bars controlled via sPOD
Freightliner Cascadia mirrors
Mirror heat controlled via sPOD​
Manually adjustable​
Converted to dual group 8D batteries (Acela)
New Centennial Commercial C-8DH starting batteries (December 2020)
Stainless steel battery trays (Acela)
Battery shutoff switch at battery box (Acela)
Winch shutoff switch at battery box
Smaller steering wheel (Acela)
Custom aluminum roof rack bars and ladders
Extensive sound deadening system (Acela + additional)
Hydronic System
Espar M12 diesel coolant heater with easy-start timer in cab​
Manual engine supply & return shutoff valves​
Arctic Fox Hotfox in-tank fuel heaters with 1/8” auxiliary standpipes​
Arctic Fox Hydra Liner heater in gray water tank​
4-circuit electric valve hydronic manifold located in custom aluminum storage box​
Custom RAM mount single DIN head unit with rear and front speakers
Rear View Safety back up and side camera system activated by reserve or turn signals
Custom RAM mount for 7” display unit in cab​
Blue Sea Systems Fast Charge 4.8A USB charge port driver & passenger sides
Rugged Radio H22 Ultimate Carbon Fiber headsets with Racing Radio SXS intercom
Scheel-Mann Vario F Edition heated seats with armrests and LMTV mounting brackets (May 2021)
Molle panel and L-track storage solutions in cab
400-watt Victron inverter in cab behind passenger side
100-amp Blue Sea Systems circuit breaker for 12v cab circuits in battery box
100-amp Blue Sea Systems circuit breaker for 24v cab circuits in battery box
30-amp Blue Sea Systems circuit breaker for camper battery to battery charger in battery box
EXTRAS
All military technical manuals including wiring diagrams
All service records
All manuals for installed equipment
Digital drawings of all fabricated items available upon request
Tactical Recovery Gear soft shackles, snatch rope, & tow rope rated for 30,000+ lbs
Sherpa winch line extension
Heavy-duty truck specific tools included such as torque multiplier, filter wrenches, and driveshaft tools
Custom sized black marine vinyl tire cover for spare
DISCLOSURES
Exhaust brake does not function, but warmup function does work. It appears to be an issue with a signal from the TCU
ABS light is active due to active braking valve circuit fault
Cruise control does not disengage with service brakes
NOTES
Only CAT fluids used in truck​
Oil changed every 6,000 miles​
Preventative maintenance services performed per the military lubrication order​
Oil sampling perform at oil changes post rebuild​
All services performed by Acela or CAT-certified shops​
Recommended cruising speed is 61 MPH with a top speed of 74 MPH​
High quality Parker or Gate hoses & fittings for all fluid systems​
2eleven
