2003 Ford E350 7.3 Coolant Filter Location
Bluvan
This little bracket placed the filter behind the power steering reservoir by bridging over it. Will likely need to be removed to get access to other bits below it but works well being at the top of the system. Your results may vary
Due to a miscommunication with the sheet metal shop I have an extra bracket if anyone is interested. I can also dig out the drawing and will post that when I find it.
This coolant filter is on a 2003 7.3. Not as critical of an add on for this motor but since this rig is just a baby at under 20k mi I installed as much insurance as I could. I sent you a pm in the event you are interested in the extra bracket.
Dynamo TCX
