montypower
Adventure Time!
Posting this to help my brother out. He's owned the Montero for about 5 years. He purchased it after returning from Afghanistan (Army). It's been his pride and joy. Probably one of the nicest Gen3 Monteros around (especially with the upgrades and extensive maintenance).
2003 Mitsubishi Montero XLS (no leather). 142k Miles
Factory Features: Massive Sunroof, 3rd Row Seating (for 7 passengers), Rear Climate Control.
2003 is the most desirable year for the Montero. 3.8L Motor (runs on regular or premium fuel - previous required premium) excellent power, 5 speed automatic with tiptronic (holds speed like a manual on hills - brilliant programming ie always in proper gear), 24 gallon fuel tank (great range), Traction Control (best out there - search you tube) works better than Land Rover or Toyota A-Trac, Unibody with full subframe (incredibly ridged chassis), Independent suspension front/rear (most ground clearance of any comparable SUV) - took mine through the Rubicon, Massive Differentials 9.5" Rear and 8.5" Front.
Upgrades:
ARB Bumper (winch Ready)
OEM Suspension with Nitrocharger Sport Shocks
Tinted Windows
Rear Roof Spoiler
Factory OEM Headlight Housings ($400/ea)
Duratrac 235/85R16 Tires (matching spare) - tires will need replacing soon
Fancy Speaker System with Bluetooth Amps, Subs, Speakers ($1,500)
Mitsubishi Dealer Maintenance Records:
10/24/2013 Left And Right Front Axle Shaft
Left And Right Front Joint
Parts and Labor: $700
8/7/2015 -- 126,666 miles
Timing Belt And Timing Belt Tensioner Replaced
Automatic Fluid Flush
Transfer Case Service
Water Pump Kit
Axle/Differential Service Front And Rear Differential
Power Steering Fluid System Flush
Brake Fluid System Flush
Heating/Cooling Installed 5901: Cooling Kit
Instal Weather Strips And Window Seal
Clip, Hood Locking
Replaced Both Front Headlamp Assembly
Install New Speedometer Cluster
Total Parts and Labor: $2,600
9/17/2015 Installed Gasket, Oil Pan Drain
Pulley, Timing Belt Idle
Pulley, Timing Belt Tensioner
Sensor, ENG Crank Angle
Oil Seal, Camshaft
Oil Seal, Crankshaft, FR
Shroud, Cooling Fan
Cover, Radiator Under
Clip Radiator Grill
Total: $530
4/22/2016 Alternator Replaced
Total : $285
8/9/2016 Replaced New Starter
Total : $240
Price : $7,500 FIRM
Located : Portland, Oregon
Contact : Sam 503-830-5440
