al_burpe
https://eastidaho.craigslist.org/rvs/d/2007-host-270-4x4-diesel/6320468616.html
This one of a kind Motor Coach from Host is a must for any sportsman. This 4 wheel drive motor coach with 2 slides is perfect for towing your toys. This motor home is on the Ford 550 Chassis with a 6 liter turbo diesel. No option was spared in making this one of a kind Host 4 Wheel Drive Motor Coach. Satellite Navigation system, 4 Captain's chairs up front, Tent area in the back for additional campsite storage or a place for an air mattress for additional people, 4-6 Volt Batteries, flat screen TV, large bathroom, automatic leveling jacks and the list goes on and on. The unit drives like NO other motor home on the market. The motor coach drives like a luxury pickup truck with none of the noise typically found on a class C Motor home. Act fast as this 1-Owner low mileage gem will not last!
Dry Weight: 14,000 Lbs.
Width: 96"
Exterior Height: 10' 6" w/o AC - 11' 4" w/ AC
Interior Height: 84"
Floor Length: 14'
Overall Length: 27'
Fresh Water: 45 Gallons
Grey Water: 35 Gallons
Black Water: 35 Gallons
LPG Capacity: 18 Gallons
Furnace: 35,000 BTU
GVWR: 17,950 Lbs. Front
GAWR: 6,500 Lbs. Rear
GAWR: 13,660 Lbs.
34,156 Miles
Heavy Duty Front Bumper & Grill Guard 4-Driving Lights
I-Max 12,500 lbs. Winch
Smooth fiberglass, vacuum-laminated exterior sidewall panels
R-12 insulated in walls and ceiling
Square-tube aluminum-framed sidewall
Ford® 550 Ford® 6.0L Power Stroke® V8 Turbo Diesel
Ford OEM 4-wheel drive
Aluminum wheels
Tires 225/70R x 19.5
40 gal. Fuel tank
5-speed automatic transmission
Four-wheel ABS disc brakes
Front and rear stabilizer bars
Front coil spring with shock absorber
4.88 rear axle ratio
Remote fill 18 gal. LP tank
Heavy duty dual chassis starting batteries
Quad 6volt house batteries
do NOT contact me with unsolicited services or offers
Width: 96"
Floor Length: 14'
Overall Length: 27'
Furnace: 35,000 BTU
GAWR: 13,660 Lbs.
34,156 Miles
Aluminum wheels
40 gal. Fuel tank
