2007 Sportsmobile 4x4 Custom - V 2.0
rmgroup
FOR SALE: 2007 Ford E-350 Sportsmobile 4x4 – V2.0 Expedition Build $95,000​
Miles: 73,468 on fully rebuilt truck (152,700 total chassis miles)
📍 Ready to drive around the world. Rebuilt with reliability, off-grid capability, and global serviceability in mind.
After a test trip to Baja in the stock Sportsmobile in 2010, I quickly realized this rig in stock form wasn’t built for real-world overlanding. Cabinets failed on washboards, and the suspension was inadequate for anything beyond REC.Gov campgrounds. So, I stripped it down to bare steel and rebuilt it to be a true expedition platform—built for self-sufficiency in any terrain, any climate, any country. Meet version 2.0, a complete ground-up professional rebuild with a focus on reliability and long-term serviceability. It’s not new anymore, but it’s incredibly well cared for, stored indoors, and has been exceptionally reliable. If someone handed me a gas card and said, “Go drive the Pan-American,” I’d leave tomorrow without a single modification.
🔧 Powertrain & Drivetrain​
  • 6.0L Diesel Long Block (pre-DEF) – rebuilt at 79,232 mi
  • ARP head studs, EGR delete, CAT delete, dual oil filter w/ bypass
  • All-new bolt-on components with engine rebuild; ECM, FICM, alternator, water pump, A/C pump, steering, full engine/trans wiring harnesses, and auxiliary cooling fan
  • New turbo, MAP, MAF, EBP sensors, EBP tube, MAP tube (all brand new at 152,600mi)
  • 5R110W Transmission – rebuilt w/ Suncoast clutch pack, 15qt deep pan
  • Atlas II 2-speed transfer case – front-only, rear-only, or true 4x4 operation
  • Dana 60 Front Axle – ARB air locker, Yukon 4.10s, 14.5” big brake rotors, new pads, Deaver HD suspension, Bilstein shocks
  • Dynatrac ProRock 80 Rear Axle – ARB air locker, 4.10s, 14.5” big brake rotors, new pads, Deaver HD suspension, Bilstein shocks
  • New HD front and rear drivelines (with new knuckles)
  • Detachable front sway bar
  • 46-gallon diesel tank, tapped for hydronic heating
🛞 Tires & Wheels​
  • Set 1: Toyo MT 35x12.5R17 on Hutchinson 2-piece beadlocks (5), low miles (11-13mm remaining of 16mm new)
  • Set 2: Goodyear Duratrac 35x12.5R17, studded/siped on Method HD wheels (5), low miles (14-15mm remaining of 18mm new)
🧱 Exterior​
  • Aluminess front bumper w/ 16,000 lb Superwinch (no key)
  • Aluminess rear bumper w/ Warn 12.5k winch, swing-out tire carrier, and storage box (no key)
  • Aluminess roof rack w/ solar and gear mounts
  • Extreme Outback onboard air compressor
  • Lighting: 50” Rigid LED light bar, 7” Hella driving spots, Rigid rear-facing lights (scene + reverse)
🔋 Electrical & Solar​
  • 2 × Zamp 190W solar panels (380W / 19A total)
  • Blue Sky Energy MPPT controller + monitor
  • 2000W TrippLite inverter + high-speed charger
  • IBS dual battery management system (in-cab remote display)
  • 3 × Duracell 4D wet-cell house batteries (~600Ah total / ~300Ah usable)
  • 120V & 12V outlets throughout
  • Focal premium sound system + Viper alarm
💧 Water & Propane​
  • 25-gallon freshwater tank, routed inside thermal zone for true 4-season use
  • Dual filtration: 3M Aqua-Pure AP110M (5 micron pre-filter) + Pentair Everpure H-54 (0.5 micron secondary)
  • Cassette toilet – cabinet concealed
  • Outdoor shower w/ curtain
  • 25 lb underbody propane tank, 2 exterior ports (grill, fire pit)
  • 10,000 BTU Partner single-burner propane stove (interior mount)
🛏️ Interior​
  • Fully rebuilt interior @ 79,232 miles
  • All new wiring, solar, plumbing, cabinetry, components, and upholstery
  • Pop-top w/ new electric actuators
  • Welded-frame cabinetry, bamboo inlays, custom upholstery
  • Sound deadening + high-performance insulation
  • Sleeping: Lower: 46” × 78” premium foam, Upper: 40” × 84” premium foam
  • Refrigeration: Isotherm 130L drawer-style 12V fridge/freezer, & ARB 37qt auxiliary 12V fridge/freezer
🔥 Heat​
  • Espar Hydronic diesel heater
  • Rixens controller w/ fan heat exchanger
⚠️ Known Issues​
  • Small tears in one of the pop-top screens
  • Rear bumper and storage box locks missing
  • Exterior paint shows wear but remains well-maintained
  • One tie rod end rubber boot is split but still holding grease
💬 Summary​
  • This is not a weekend camper—it’s a professional-grade overland platform capable of international travel and deep backcountry isolation.
  • Every major system has been overhauled using best-in-class components and expert craftsmanship.
  • It’s reliable, field-serviceable, and beautifully executed.
  • Ideal for serious explorers, skiers, nomads, or hunters who need a dependable 4x4 home on wheels.
  • It’s ready for a new adventure, no wrenching required.
  • Serious inquiries only. Title in hand.
  • Fly into Bozeman — drive away. Delivery may also be available.
IMG_5692.jpegIMG_5691.jpegIMG_5672.jpegIMG_5673.jpegIMG_5666.jpegIMG_5661.jpegIMG_5648.jpeg
Great rig! Sooo much better than a factory SMB!
Can I ask who the rear sofa bed and 46-gallon tank are from?
Answering a couple questions:
The work on the vehicle was carried out by a couple of different specialty contractors. I did the plumbing, electrical, cabinets and general re-build. Mike Wood was the upholstery specialist for the interior paneling, seats, and flooring. The motor replacement by GOS Performance, and the undercarriage work by a local 4x4 fabrication shop. I tried to select the best specialty technicians for each specific phase, and in this case had everyone working and coordinating together when there was overlap. I'm quite pleased with the results.
We're selling as I recently completed another build on a larger platform. Unfortunately the SMB is now just taking up shop space.
No, I'm not interested in another camper type trade. I would however consider a Defender 110, if it was of comparable quality/re-build. Maybe a Carrera 4S? Perhaps something from AEV may be worth considering??
Most likely from sitting around to long. There was minor corrosion on the turbo vanes when we pulled it apart. I decided to put a new one in it vs. trying to clean it.
5mouse
