2008 Argo avenger 750EFI land and water
LandRoverHyter
2008 Argo avenger 8x8
112 hours
20-25 mph on land
5mpg on water
Will Deliver
$11,000
Located in Versailles Kentuky
Call for more info 859.536.38o5
http://argoatv.com/products/avenger-750-efi
8x8 Avenger 750 EFI Specs
Engine 4 cycle OHV V-Twin gasoline engine, electronic ignition, full pressure lubrication and oil filter. 3 year warranty
Model Kohler Aegis LH 775
Horsepower 30
Displacement 748cc
Cooling Liquid Cooled
Starting Electric
Brakes Hydraulic
Steering One-piece ergonomic handlebar steering control with mounted brake lever. For safety and ease of handling, the ARGO two mode steering for increased efficiency and incresed agility.
Controls Right-hand twist grip throttle gripl. Light switch and ignition switch.
Clutch Belt-driven, Continuously Variable Transmission (CVT) maximizes engine power to the transmission.
Transmission Planetary differential transmission with High and Low range; Forward, Neutral, Reverse.
Drive System Roller chains drive machined sprockets that are spline-fit onto 1 1/4" diameter axles. Bearings are greaseable.
Frame Formed steel channel construction, welded for high strength and durability. Polyester powder coated for lasting protection.
Body Vacuum formed High Molecular Weight Polyethylene
Full Skid Plate Standard
Load Capacity - On Land 1150lbs / 521kg
Load Capacity - Rear Compartment No Restrictions
Load Capacity - On Water 1000 lbs / 454 kg total
Towing Capacity 1800 lbs / 818 kg
Seating Capacity 6 persons on land, 4 persons on water
Fuel Capacity 7.1 Us gallons (27 litres) See-through polyethylene fuel tank. 8 hours of operation.
Speed (on land) 20 mph / 32 km per hour
Speed (on water) 2.5 mph / 4 per hour
Shipping Weight 1250 Ibs/570 kg
Axle Bearing Extensions Front - Standard Rear - Standard
LCD Digital Gauge Cluster Speedometer, Odometer, Voltmeter, Hourmeter, Tachometer, Engine Coolant Temperature, Low Oil Pressure, Parking Brake Reminder lights and Check Engine Light.
Tires ARGO AT189 25x12.00-9 NHS
Ground Pressure 2.1 psi (14.5 kPa) using tires, 0.67 psi (4.6 kPa) using tracks
Ground Clearance Tires 9.5 inches - 240 mm
Ground Clearance Tracks 10.5 inches - 265 mm
Operating Conditions All weather,all-terrain,-40°C to +40°C
Dimensions
tbnd88
