2008 Dodge Sprinter 2500 170 WB $39000 OBO
Fourteen32
I've lived full time in this rig for 6 years, I thought I’d live in it forever, but … life. This van has been more than a home, and I’m stoked to share it for more adVANture! $39500 OBO.
ELECTRIC
  • Two Renogy 12V 100Ah (200 total) Lithium LiFePO4 Deep Cycle Batteries
  • 400w Renogy flexible solar panels on the roof
  • Renogy 2000W Pure Sine Wave inverter 12V DC to 120V AC Converter
  • Renogy 12V 60A DC to DC charger
  • Renogy 40A Rover charge controller with bluetooth to monitor from your phone
  • Fuse block wired into the batteries and everything else in the van (pumps, switches, outlets, fan, lights, fridge, etc) to protect anything from blowing out
BUILD
  • Aftermarket CR Lawrence venting windows on both sides
  • Dometic Fantastic Vent Fan (above the bed) on exhaust to pull air into the van
  • Walls and ceiling is both 1.5" (ceiling) and 2" (walls) foam insulation boards with all cracks, crevices and spaces stuffed with Ultratouch denim batting
  • Reflectix and a layer of Rattletrap
  • 12 LED puck light in a warm tone, configured as three separate controls in sets of 4
  • KING size bed (technically it is just under king width, but it is as wide as you can go (wall to wall) and 80 inches long
  • 4 inches of memory foam mattress on a Den-Dry Mattress Underlay
  • Bed is high enough to fit mountain bikes, road bikes, etc, in the garage underneath plus a TON more gear for pretty much any activity you're into
  • Sink cabinet extends into entryway about 12 inches, leaving you with just under 4 feet of width for getting in and out of the van,
  • Brand new black sprayer (not in pics new) for filling up large pots, water bottles, and outdoor shower with a swivel.
  • 12v Shurflo water pump under the sink, drains through the floor of the van, so use biodegradable soap or place a container below to catch the water when in use.
  • Two 6 gallon Reliance jugs under the sink for fresh water storage.
  • Nature's Head composting toilet
  • Dometic 65l fridge/freezer combo. The left side is a freezer section leaving the other 2/3 to be used as a fridge. Thats right, you get freaking ice cream in this van!
  • Wedgewood Vision propane stove, also made by Dometic
  • Manchester propane tank in the cabinet directly below the stove so it's easy to manually open and close the propane valve
  • Large CLOSET for hanging clothes, coats, dresses, or other larger items and tons of other storage
  • Diesel heater installed under the passenger seat; that's right, this is an all season rig. No shoes, no shirt, no problem!
MECHANICAL
  • 230,XXX miles and I’ve replaced just about everything mechanically, including an OEM engine from Mercedes in 2022 (the engine will likely outlast the rest of the rig, perhaps another 15 years depending on how you use it)
  • BF Goodrich ALL-TERRAIN T/A KO2 - SIZE: LT265/75R16 5/01/19 (about a year old)
  • Replaced Alternator
  • Replaced front and rear brakes, pads, and rotors
  • Replaced windshield (several times, needs another)
  • Replaced cable track for sliding door
  • Replaced fuel hose and clamps
  • Replaced EGR Valve
  • Replaced PCV Valve Assembly
  • Replaced Turbo Charger and hoses (done in 2020 but also in 2023 with new engine)
  • Replaced air intake tube and seal
  • Replaced charged air resonator seals and o-rings
  • Replaced EGR Tube
  • Driver and passenger airbags replaced due to recalled parts
  • Replaced hood latch and wire
  • Replaced all 4 tire pressure sensors several times (but the dash light is still temperamental)
THE UGLY
  • Waiting on parts to replace the DPF, may or may not need replacing according to Mercedes, but the computer thinks so sometimes. I plan on doing this but if it sells first the cost will come out of my asking price. Mercedes just did a two day diagnostic and forced regen and recommended a new DPF and sensors though the check engine light is not on.
  • The ridge door lid latch recently broke and I haven't been able to source a replacement from Dometic. It may decrease some efficiency, but I haven't noticed any change in the operation of the fridge or freezer and honestly keep forgetting about it.
  • The ESP and ABS family of dash lights are on, Mercedes advised that the issue is that the computer needs replacement but is no longer being manufactured, and because they've seen a lot of issues with workarounds being implemented, they advised to leave it be.
  • The interior fittings, floors, cabinets, counters, etc., are in good shape considering six years of full time use, but there are definitely scuffs, hinge breaks, the paint could use a refresher, some water spots on the floor, etc.
  • Exterior shows some dings, dents, some rust, and scratches. Some were there when I bought the van but I've definitely added some signs of adventure. I treated paint scratches to prevent further rust last year.
ALL of this is reflected in the price.
Located in Fresno, California. Willing to deliver (with a deposit) anywhere up the west coast, I'll be making my way up to Vancouver Island in the next few weeks.
Asking $39,500. Open to reasonable offers. Also open to cash plus trade for a super cheap truck/SUV/van to bop around for the time being.
The exterior length is 245.9-inch and the exterior height is 94.4-inch with an exterior body width of 79.5-inch. It has regular vehicle A/C, no exterior unit.
2eleven
