2009 FWC Grandby - Four Wheel Pop-Up Camper
shanz3n5
SOLD
Wade....Good Luck and blessing for your new adventures and exploration.
I will miss her.
Stay in touch with us here as well as other truck campers. This Forum site, adventure portal and wonder the west is where you will find a lot info for the future expeditions for u.
~John
10k or BEST reasonable offer.... do your searching.... this price is fare
10/2/16
KEEP CHECKING BACK ..... EDITING POST DETAILS AND PHOTOS
PLEASE.... Serious Inquiries only
Many more defined pics and videos... available upon request
2009 FWC Grandby - Excellent Condition
This Camper is just about Immaculate.
All camper specs are listed at the bottom of posting
I am the second owner, and purchased the "2009 Grandby" in July 2013. The original owner NEVER used it. He purchased it to use with a "Pilot Truck" business that never got off the ground. He stored it inside for 4 years. No joke....interior was still wrapped in plastic. I drove from SoCal to Iowa for the purchase.
I purchased this camper for "off the beaten path" camping to enjoy motorcycle riding, country exploration and fishing with my daughter. Over the last 3yrs it has been nothing but the best of experiences and adventures. It is hard to post this camper for sale, I even custom built a new truck bed just for this camper and excursion gear. The family has grown now to 4 people and 2 dogs. And it just no longer can accommodate the needed space.
I have all original documents / manuals from manufacture-installed equipment with exception of purchase order. It only has had a few modification, done by me, which I will explain below.
Partial Excerpt from other source:
{The Grandby is our bestselling Four Wheel Camper model that fits on full sized truck with an 8 foot "long" bed. The camper fits flush with the tailgate removed making the camper exactly 8 foot long. This is also a great option for someone with a short (6.5') bed looking for some extra room. The Grandby can be used on a short bed truck with the tailgate down. Its extreme durability and is unmatched by our competition. The factory builds the Grandby with plywood, not particle board and an all-aluminum flex frame. Four Wheel Campers leads in the art of making campers that feature roomy interiors with limited space.
The Grandby model fits full size, 1/2 ton, ¾, 1 ton long or short bed; regular cabs, extended cabs, or crew cab trucks. It has also been used on open cargo trailers for those who may have a SUV. It maintains a 10" low profile above truck cab, allowing for increased fuel economy, and its low profile enables it to fit inside your garage. The interior height when the camper pops up is a full 6'6." Large windows in the pop up material allow an amazing amount of sunlight to come into the camper. }
Specs:
Dimensions / Weight:
• Dry Weight: 840 lbs [2009 Base Model - (110 lbs lighter then newest model)]
• Height Up: 83-3/4" (truck bed floor to vent top)
Down: 59" (truck bed floor to vent top)
• Roof Length: 144" [overall L = 148" (lights and brackets)]
• Floor Length: 96 -- 3/8″ [(plus 1" rear door frame & 1-1/2" front bumper wall beyond floor length) = 98-7/8"]
• Body Width: Rear Wall, at base, 57-7/8"
Rear Wall, 22" rise from floor, 80-1/2"
Rear End Side panel Length, L/S 21 3/8", R/S 207/8" , 4 7/8" off set in
• Body Width: Front Bulkhead, at base, 48-1/8".
Front Bulkhead, 14" rise from floor, 57-5/8"
Front Bulkhead, 21-3/16" from floor, 80-1/2"
Front Bulkhead to Rear Width Offset, beyond wheel wells, 4 7/8" extension: 4-7/8" ea. side
• Adult Sleeping: 3-4
• Extended Interior Height: 6' 7"
• Interior Door Frame Exit Height 48"
• Roof/Wall Framing: Aluminum
• Exterior Material: Aluminum upper, ext grade paint plywood lower base. Excellent condition. (1 small dent front right corner r oof cap- no issues)
• Fresh Water Capacity: 20 Gallons
Standard Features and Options: (+ custom mods)
• Aluminum Flex Frame
• 4, Custom 3 side Jack Brackets, with extensions (Mod)
• 4 Mechanical Camper Jacks -- Rieco Titan 2000#
• Finished Wood Interior
• Extended Cab over Bed w/ Mattress
 78x48 ext 78x65
• Formica Counter Tops
• Deluxe Fabric Cushions
• Privacy Curtains
• Screen Door
• Stainless Steel Kitchen Sink 10x14
• FloJet 3526 Auto-Electric Water Pump
• Suburban SDN2 - 2 Burner Propane Stove w/ Cover
• Engel 32qt MT35F-U1 Dual Volt AC/DC, Frig / Freeze with mounted locking tray (Mod)
• Dual 6V 220Ah batteries in box -- Life Line wet mf agm sealed (Mod)
• Sure Power Battery Separator with Smart Solenoid mdl 1314
• 120V Electrical System, 3 duplex outlets
• 30amp IOTA Power Converter w/ IQ4 Smart Charger
• IOTA IDP-30 Distribution panel
• (3) 12 Volt Outlets
w switch
• 12V Interior Lights
& Outside Porch Light
(2)
• Pre-wired for Solar
• (2), 10 lb. Propane Tanks
• Fire Extinguisher
• LP/CO Detectors &
Smoke Detector
• Atwood 8012 Forced Air Furnace w/ Thermostat
• 2 Roof Vents, 1 with Power Fan-Tastic Vent Fan -- 3spd, bi direction
• Side Dinette with roll over seat for bed -- sleeper 75x20, and 2pc table
• Extra stoage cabinet 32x5.5 above dinette
• Extra storage clear chest of drawers behind toilet
• Portable Toilet -- Dometic Sealand 975, Self contained 5gl holding tank, <1qt flush, full size seat with Custom Base Cabinet (Mod)
• Rear Wall Steps (better access to the roof)
• Heavy Duty Rugged Vinyl Soft Side Wall
• Thermal Pack
• Gas Strut Roof List Assists
2, interior
• Insulated Side Walls & Roof
Exterior:
Left Side Wall
• 2 running lights and reflectors
• Water -- fresh fill, domestic connection, sink drain
• 120V 30A shore power plug
• Furnace Exhaust
• Truck / camper power connection plug
Rear Wall
• Entry door with screen door, window and curtain and new door stop
(door frame was removed and resealed last summer)
• 2 wall steps, porch light
• Propane storage cabinet
• Fresh water drain
• 3 running/brake lights
Right Side wall
• Long window -- ½, 2 panel crank & ½, emergency escape
• Porch Light
Front wall
• large emergency escape window
• Bulk head bumpers
http://www.truckcampermagazine.com/buyers-guide/pop-up/four-wheel-pop-up-camper/
http://www.thecampingsource.com/cla...Popup_pickup_camper/item/1221/classified.aspx
http://www.fwcjh.com/granby-full-size-truck-long-be
http://www.fourwh.com/product/grandby-long-bed-popup-truck-camper-8-foot-bed/
M meadow build
