2009 Schutt Industries M1101 Overlanding / Camping Trailer
Mustangski
2009 Schutt Industries M1101 Trailer
  • 2600 lbs dry / 520 lbs tongue weight (measured with calibrated shipping scales)
  • American Racing AR23 black wheels w/matching spare
  • Ironman Radial LT235/85R16 Tires
  • Custom 2” pintle hitch included that allows level towing of trailer
  • Recently re-packed wheel bearings with new wheel seals
  • Converted to 12v, 7-pin trailer harness
  • Security: Pintle lock, wheel lock
  • Metal top cage w/ removeable center (bolts, not super simple but can be removed)
  • Cage sits approximately 75” tall measuring from the ground.
  • Brackets welded to side for awning mount (awning not included)
  • Highway Products truck slide, lifetime warranty
  • Power Tank bracket mounted on rear w/10 lbs propane tank.
  • Dual WeatherGuard boxes on each side, lockable
  • Rear 2” receiver made from square steel tubing (mount additional rack or bike rack, etc.)
  • Water pump/Propane heater
  • FloJet electric water pump mounted inside front Weather Guard box
  • Powered by battery box listed below
  • Camplux 1.32 GPM propane water heater mounted inside pelican case.
  • All water and propane connections are quick disconnects
  • Leveling jacks/stands
  • (2) Front pin adjustable legs
  • (2) rear crank adjustable legs allow near perfect leveling
  • LED Reverse lights
  • LED lighting
  • Powered by custom battery box that uses factory trailer wiring and 7-pin connector
  • Dual USB Charging port near rear of trailer
  • 12v emergency style rechargeable flashlight w/mount
  • Fire Extinguisher with rear mounting bracket
  • Shovel, axe, tool brackets
  • Overland Vehicle Systems (OVS) Nomadic 4 Roof Top Tent
  • Tent Comes with Annex
  • https://overlandvehiclesystems.com/...an5mbX7udH6OOItFbRhhoTKngX3GcLF0aAiymEALw_wcB
  • https://overlandvehiclesystems.com/...nex-green-base-with-black-floor-travel-cover/
Moving and can’t take this with me, looking to sell it. A lot of work already complete on this trailer and makes a great trailer to go anywhere you need to. Everything works, our family has had a lot of great trips with this.
Can't seem to get photos to load, see the link below for photos.
$9,000 w/tent
$8,000 w/o tent
5mouse
