justbecause
perpetually lost
2011 Nissan pro4x with the luxury package
asking $12,000 OBO
you can view an inspection we had preformed here https://tvpx.autovitals.com/Inspect...RHA&guid=456690f7-ca5f-434a-ac73-79ffef5650f1
since the inspection the battery, and air filter have been replaced, brakes were flushed.
Rack and pinion does need to be replaced, as well as the valve cover gasket and spark plugs will be due to change again at 200k miles.
Windshield has significant crack running side to side. Also highlighted in pictures below are the dents in the driver side bed. The rest of the body is in good shape.
We purchased this vehicle with 50k miles. I have done full synthetic oil changes ever 5k miles. I had the ATF changed at 60, 90, and I believe at 120k miles. I would have to double check the 3rd change.
Rear diff oil was changed when I installed an extended breather around 100k. I have a gorilla offroad rear diff cover but I decided not to use it and keep the stock cover.
Tires are relatively new, 235/85/16 General Grabbers ATIIs. I could check with firestone on an install date/mileage for a serious buyer.
The suspension system is OME heavy springs front and rear and I replaced the shocks last year with bilstein 5100s. The general grabbers are comfortable on the road without much noise and have always done well for me while offroad.
I assume the winch works but I disconnected years ago and have never had a reason to hook it back up. Rear locker works, I cycle 4h 4L and engage the locker regularly to keep everything moving. Windows and sunroof work and do not leak. Seats are in good shape. I have some nice protective floormats and the OEM matts. Rear seating area is messy at the moment (7 year old and 3 year old)
Topper is not 100% water tight. It never bothered me enough to raise it to install a seal between the bed and topper.
Located in Montgomery Alabama. This is my wife's daily driver. The kids are growing and we are stepping into a camper. The truck and our van are both available. https://expeditionportal.com/forum/threads/2001-econoline-e350-7-3-power-stroke-diesel.235855/
I'm happy to discuss anything about this truck or answer any questions
asking $12,000 OBO
