2013 Toyota Tundra major build, expedition ready
cwvandy
Modified ad. Decided after driving the truck again that I am not going to sell parts. Will sell with and without Rooftop tent and Bat Awning. $42,000 with the pair, $40,000 without. Truck is perfect and I would prefer to keep it rather than dismantle. If someone wants the truck and decides to sell off parts obviously they can. Edits done to original posting to reflect changes.
cwvandy
I have had several inquiries lately about removing the bed slides and whether there would be holes.
The bed slides are through bolted (via a custom flat bracket) to the frame using the existing bolts that hold the bed to the frame. To remove the slides they are simply unbolted from the bracket, removed, and the bracket unbolted from the bed/frame of the truck. No holes were cut in the installation. The process takes under an hour. Because there are two separate slides, the weight is distributed to two units making removal and installation easier/lighter than if there was a single slide.
cwvandy
Photos of bed slide attachment points.
RAM5500 CAMPERTHING
OG Portal Member #183
Congrats on sale! I used your build for ideas for mine!
Any more info or pics regarding the Transfer flow skid? I am looking to do the same on mine and ideas are always welcome from those that have done it!
Thanks!
iStan814
