2014 fuso fg overland camper, open to trades up down or even
i have added rear ac to the sleeping compartment, changed colors to the upholstery, added fox remote reservoir shocks as well as shot new photos. truck is ready to camp
Bought this last fall, took a few trips, and have spent a total of 4 weeks camping in this truck with my kids. I made a lot of little changes and finished off a lot of the items that weren't complete at time of purchase. My main thing was to make it so 3 people could travel, and up to 4 camp in it. I wanted it to be as good as a Fuso FG could be on the highway. Time to move onto something else, 44,750 miles. my asking price is $149k, I am open to full or partial trades (nothing in particular feel free to send anything and maybe we can put a deal together. Located in wilmington nc
Just ~23' feet in length this vehicle is easy to drive, and easy to park (even in a crowded parking lot!).
With an easy electric "pop-up roof" design, your "camp" sets up in just moments... you'll be sitting and enjoying a cold beverage just minutes after arriving at your dream destination.
Take down, is just as fast and easy.
Complete with all the creature comforts that you ever wanted while enjoying the outdoors.
Your "not so excited about camping" partner - will now love this outdoor lifestyle.
From Solar Power, to new wheels, tires, and suspension... this rig has upgrades galore!
Super clean, well maintained... with a clear title!
Chassis:
2014 Mitsubishi Fuso FG
America’s only four-wheel drive cab over, the Canter FG4X4 goes where no other trucks can, thanks to excellent ground clearance, locking hubs and constant-velocity joints for sure-footed tracking and turning. Plus, heavy-duty axles and all-terrain tires, transfer case and more. No matter how sloppy or slippery conditions get, the FG4X4’s Duonic® transmission feeds continuous power to all four wheels to help you maintain maximum traction.
Fuel Tank Capacity: 30 Gallons.
All Terrain Warrior - Parabolic Suspension
The parabolic leaf springs by All Terrain Warriors offering the best on and off-road ride for the Mitsubishi Fuso. This design offers a comfortable ride while on-road, but gives a full 24 inches of articulation for off-road use. These bolt-on springs perform brilliantly over all types of terrain.
All Terrain Warrior - Super Single Wheels
Super Single Wheels convert your Mitsubishi Fuso from a dual rear wheel setup to a single rear wheel that tracks with the front wheel. These wheels are DOT approved, ISO 3894 tested for Commercial Wheel Fatigue, and increase the wheel load rating from 3858 lbs to a staggering 13,227 lbs per wheel.
Other benefits of these wheels include increased rolling diameter resulting in higher gearing that improves fuel consumption and overall performance at lower engine speeds while reducing wear on the drive train and tires.
Other benefits of the Super Single Wheels include:
  • Valves on both sides for easier inflation
  • No rocks or other debris caught between the duals causing sidewall damage
  • Brings front and rear wheels into the same track which greatly improves performance
  • Extremely heavy duty 16 ply tubeless tires with load ratings increased from the standard 3197 lbs to 6393 lbs per tire and high puncture resistance
  • True Mud ‘n’ Snow tread pattern which offer improved traction in all conditions with greater ability to traverse uneven ground, rocks, obstacles and corrugations
ATB Helical Gear Limited Slip Differential
Auto Torque Biasing (ATB) Helical Gear Limited Slip Differential (LSD) is a direct replacement for OEM factory open differential units on all Mitsubishi Fuso FG. It is backed by a lifetime warranty and has fully automatic and progressive operation. The ATB never locks like a traditional locking differential, but seamlessly and smoothly transfers power and torque away from a spinning wheel to the one with the most traction. Off-road, this significantly reduces wheel spin, torque steer, and under steer during cornering while enhancing performance in mud, sand, and snow. The unit is built to ISO9001 standards and over 100,000 have been built and installed since the 1980s.
Toyo Hyparadial 35” Tires
285/70r19.5 M608Z - Four-belt construction combined with an open-shoulder lug design delivers outstanding traction, high mileage, and excellent retreadability. 16 PLY Tires.
Return to center steering stabilizer for better drivability
Exterior Features:
  • Carefree Freedom Crank Out Awning
  • Dometic “Seitz” Double Glazed Tilt Out Windows
With built in shades and bug screens.
  • Outdoor Shower & Storage Locker.
  • Custom Front Runner Roof Rack
  • 60” LED Light Bar Mounted On Roof Rack
  • Aluminess Front Bumper, with Brush Guard & Winch
  • Please note: Winch & Lightbar are installed, but not wired. STECH Switch System, for installation included!
Cabin:
  • Crane Composites Body
A well-engineered, high-gloss, composite fiberglass sidewall panel. The Noble Classic panel is the most popular exterior finish choice by a broad range of manufacturers throughout the industry. Made in the USA.
  • 24” Pop Top
Triple layer, soft flex liner wall, with quiet/opaque built in bubble-foil reflective insulation.
  • Tork Lift Glow Step
Power:
  • Renogy 40 AMP Commander Solar Charger
  • Renogy MT-50 Remote Tracer Meter
  • 2 - Renogy 280 Watt Monocrystalline Solar Panels
  • 2 - Renogy Deep Cycle Pure GEL Batteries 200Ah
  • Go Power Pure Sine Wave 1000 Watt Inverter
  • WFCO - 35 AMP Power Center
Water & Waste:
  • 30 Gallon Fresh Water Tank
  • 3 Stage Water Filtration System With 3 Stage Water Purification With 14 Watt Germicidal UV Lamp
  • Thetford C-402C Cassette Toilet With 5.1 gallon Waste Tank
  • Girard GSWH-1M Tankless Propane Water Heater
  • Indoor Shower
  • Outdoor Shower
  • FloJet 12v Water Pump
HVAC:
  • Espar Airtronic M D4 Diesel Air Heater
  • ProCom Heating - Propane Heater
  • Fan-Tastic Vent 3 Speed Fan
  • ac added
Kitchen & Dining:
  • Norcold 3.1 Cubic Feet Combination Refrigerator/Freezer
  • Dickinson Marin 2-Burner Stainless Steel Propane Stove
  • Custom Dinette With 1000 Denier Coated CORDURA® Nylon Fabric Seating.
Sleeping:
  • Queen Sized Bed Platform With Tuft & Needle Mattress
  • Under Bed Storage System With Lift System
  • Dometic Sunroof Over Bed
  • Full size bed at dinette
Convenience Features:
  • Dirt Devil CV1500 Central Vacuum With Vroom RV Retractable Hose System
  • 12 USB Ports
  • 6 - 15 Amp Power Outlets
  • Under Cabinet LED Lighting
  • Ram Mount - Ram Tough Tracks For Device Mounting
  • Pyle DVD/CD/MP3/USM/ bluetoothStereo With Indoor & Outdoor Speakers
Free delivery in the US.
Hey Aaron, I will be calling the NC DMV tomorrow and hoping they have answers to my concerns. The only thing is the batteries needed to be updated to Li-Ion. Willl update you. Thanks
Sounds good. I'm an Nc dealer so I can title it for you. If you have any questions my cell is +1 (910) 465-0270 Talk soon
MOLLYmaz
