This camper was bought to use for trips to the Rockies and improvements were made to make it work perfectly on long distance trips. The axle has been flipped to increase clearance and make room for LT215/75r15 tires with real speed ratings to allow travel at posted speed limits anywhere in the country. Those tires are new this summer and the spare is the same as the tires on the road. A charging center has been added inside to add 12v plugs and USB ports for charging whatever you need. A roof rack was added to mount a 100watt solar panel. That is fed through a MPPT charge controller to keep the Group 31 AGM topped off. I also added an outside wash down setup with a remote switch for the water pump to allow you to clean things off or fill water bottles without opening up the camper. Tons of storage for a popup. The AC will run on a Honda 2kw generator. Has an electric winch to raise and lower the top. The camper just completed a 4000 mile trip to Wyoming with zero issues. The camper looks as close to new as a 4 year old camper can be. You will not be disappointed. This 12ft box camper can be towed by almost anything but opens to a full 23 ft long with tons of room. Has more clearance than my Ram 3500 on 36's. The wife wants something with a bathroom. Ready to rock and roll.
$6950 OBO
Located in Houma LA
SOLD
$6950 OBO
Located in Houma LA
SOLD
